Konica 1015 copier with image ghosting problem
I work at a non-profit that has a copy Konica copy machine that has sever ghosting issues. It is possible that toner for a Konica 3135 has been used in the machine. Could this be the cause of the ghosting, or is more likely a drum issue?
  • zoomart Sep 17, 2008
    The copier was donated to our art center, so I don't know the history. There are several empty Konica 3135 toner bottles in the storage compartment ingredients listed as Styrene-Acryl Rsin. Wax 1, Wax 3, carbon black. There are also empty Konica 1015 bottles (machine is a 1015) ingredients listed as Polyester Resin, carbon black, Wax 1, Wax 3.
  • 2,794 Answers
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Posted on Sep 17, 2008
  • Tim Babcock
    Tim Babcock Sep 17, 2008
    Does it have a Konica part number on the bottle?
    It could be ok since it's the same brand.
KONICA 7272 CODE SC49-01
Image processing board failure. I would first check all the connection on the image processing board pull each connector one at the time and check for a bent pin, worse case the image processing board is bad, doubt you can find one a Legacy Konica Machine Konica is now KonicaMinolta.
Jan 21, 2015 | Konica Office Equipment & Supplies
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
Konica 1015 copier has been in storage for 10 years
You need a drum cleaning blade. These blades will go bad if left unused for that much time. This part cleans all that toner off of the drum in between copies. Cheap part at about $25.00 to $35.00
Just google konica 1015 drum cleaning blade and you will find one.
Dec 28, 2009 | Office Equipment & Supplies
My printer is leaving faint marks of other words down the side of the page...any way to fix that?
Yes, It sounds like a ghosting issue. Several components can cause a ghosting issue. The distance between the first occurance(the one on purpose) and the second occurance(ghost image) can determine the part of the machine causing the image problem
56.6mm - Fuser
54.5mm - Transfer Belt
75.4mm - Drum unit (1 of toner carts)
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Konica copier 1015 copies come out black what is the problem? please help trouble shoot this.
The exposure lamp (light source) that illuminates the original has failed. This may be fused in your machine but the fuse rarely blows without reason.
You should be able to verify this pretty easily by lifting the cover and doing a blank copy.
Oct 16, 2009 | Konica Minolta Office Equipment & Supplies
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Copies have ghost image
yes. although I would first check the fuser unit. It is located the exit side of the copier. let the copier cool down before handaling the teflon fuser roller. The upper roller has a teflon coating, if it is worn the image will not transfer properly to the paper thus leaving a duplicate / ghost image. Good luck
Nov 24, 2008 | Office Equipment & Supplies
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Error code C-0510
Code C-0510 means a low fuser temperature.
This can happen after a long copy job has been run.
To clear the code:
Power machine off
Turn on the machine with the stop key held down.
Turn off, then on again.
The code should be gone.
Apr 08, 2008 | Konica Minolta DiALTA Di183F Copier
426 people viewed this question
jasbo
jasbo
