Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Barracuda hard disk 80gb
I have a problem regarding my harddisk.when i install windows xp by booting from cd rom.After dos installation of winxp when it restarts my harddisk is not getting boot.I have set 1st boot device to harddisk still its not booting from hard disk.plzz help
  • ronaldo9 Sep 17, 2008
    when i run fdisk it shows error reading fixed disk.But it shows no error when i partitioned with winxp setup.
Make sure you have the boot drive on the master of the IDE cable... and make sure your jumpers are set appropriately
Posted on Sep 17, 2008
  • 171 Answers
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
  • Todd Gale
    Todd Gale Sep 17, 2008
    Do you have a CDROM drive connected to the same IDE cable as the hard drive? If so, move this to the other IDE connector. This is a known issue with some drives, especially smaller volume hard drives. This should fix that problem.
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
How to set up windows xp to laptop without using cd rom
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
May 08, 2010 | Microsoft Windows XP Home Edition
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
Windows wont start up.
Yes you need winxp or recovery disk.
Then boot your computer with that disk.
For that put that disk in cd rom.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option then set first boot device as your cd or dvd rom.
Then save settings then it boot with that winxp disk.
Then follow the procedure you get message when it find your previos version of windows then press "r"
then it repair your winxp.
Let me know if you need more assistanse.
Thanks.
Sep 02, 2009 | Microsoft Windows XP Professional
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I have HP laptop with Windows OS.Can I ADD Windows XP OS?
yes you can install winxp if you have winxp bootable disk.
Boot your computer with winxp disk.
For that insert winxp disk into cd or dvd rom then when you power up press F8 or F5 or F12 to get first boot option then set first boot as your cd or dvd rom then you can boot computer with disk.
Jul 29, 2009 | Computers & Internet
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Hard drive failure
Hi, you have nothing to type there. You mean you have chosen the 1st section that opens recovery console,right? not that one. You should see the Terms of Agreement in your WinXP cd first, press F8. A section containing to install a Windows XP appears, Press Enter. Then that's the time it will search for your previous Win xp installation. In will then let you choose whether you will install a fresh copy of WinXP OR to Repair it. Choose the Repair. It will automatically repairs and format your Harddisk without deleting your files in it.  IF there's no Option to repair it, that's the time you will have to go to Recovery Console.
  • To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
    For information about a specific command, type help commandname at the command prompt, and then press ENTER.
    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
If still you cannot get through to that, drop me a comment again and tell me what you have done. Feel free to ask me.
Dec 27, 2008 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
202 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
