Question about Dryers
Kenmore electric 80 series dryer not heating - Dryers
  • 4 more comments
  • deanweiger Mar 21, 2009
    No heat
  • sjdds Apr 15, 2009
    Dryer comes on, turns but no heat
  • aolvido Apr 24, 2009
    my series 80 does not heat up although from the start of the cycle, you can hear the burner light up but then, I don't think it stays on long enough to dry. I cleaned the air duct passage.
  • valeroj04 May 16, 2009
    kenmore 80 series dryer does not heat
  • Anonymous Mar 21, 2014
    Kenmore 80 series electric dryer heat work but spins slowly
    Kenmore 80 series electric dryer spins slowly
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you feel confident here are the main things to do on checking for no heat Electric Heating Dryer:
1 Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most dryer models).
If you have 220v there the heater element is out.
2 If you don't have 220v on the terminals of the heater the problem is in the controls.
The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating thermostat(s), are all suspect and have to be eliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
No heat and we changed the thermal control for high heat coils for heat are not broken please help
Posted on Sep 01, 2011
I would like to know if this Dryer is lit by a pilot or is it lit electrically. I have searched in vain but no pilot. It is a gas dryer and I took the back off and only the Gas feed goes under the back with no way of getting to that part without taking off the front and I don't believe you have to go through this ; just to light a pilot if that is the case.
Posted on Sep 22, 2008
  • 958 Answers
Could be the thermal cutoff .
do you have schematics on the panel of the unit?
tnx 4 using fixya,
drcool
Posted on Sep 18, 2008
I have a 80 series kenmore gas dryer no heat were can the problem be?
Posted on Apr 18, 2009
Kenmore Series 80 Dryer not drying with heat. Cool air only
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 62802 Electric Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My Kenmore 80 Series dryer is no longer heating up? What part needs to be replaced??
Gas or Electric? If Gas it could be the gas valve isn't opening, this keeps the burner from lighting. If electric your heating element is most likely burned out.
Aug 03, 2010 | Kenmore 84052 Dryer
MY KENMORE 80 SERIES DRYER ISN'T HEATING
remove the entire exhaust vent and clean it thoroughly. Any build up of lint inside of it will cause the moister sensor in the dryer to shut down the burner or grid which ever you have, gas or electric
After cleaning it and it still does not work correctly the sensor is at fault and needs to be replaced
May 17, 2010 | Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
2,963 people viewed this question
Top Dryers Experts
