Posted on Sep 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MP 780 Front door will not close - Canon Office Equipment & Supplies
Anonymous
Level 3:
Master:
  • Master 441 Answers
  • Posted on Sep 17, 2008
Anonymous
Master
Level 3:
Master:
Answers
441
Questions
0
Helped
141412
Points
1131
If you lift the top of the printer (the part with the scanner and the automatic paper feed), you can really hose things up if you are not careful and gentle.
It's easy for the whole top to just become unhinged from the back because of the poor design (my opinion) of how the top part sits in/on the rest of the printer. If you are not careful, the top can become unhinged when you just lift it up to change the ink cartridges (especially if you don't pull on the proper place to lift the top. Read the manual regarding changing the cartridges).
Anonymous
Level 3:
Genius:
  • Master 1,847 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1847
Questions
Helped
553244
Points
4940
Do you see any laches broken.
Ricoh aficio MP C3002 where is the waste toner located
To the left of paper tray 1. Small door with one screw from the top. Open front door to remove screw from this small door. Close front door and open small door. Slide waste bottle out the front of machine.
Add toner aficio mp 1900
open the front door of the machine.
remove the toner unit gently .
replace toner bottle.
refix the toner unit ans close the door .
wait for toner to load.
good luck..
Mp 161
open the right cover where you normally remove the paper jams,then open front cover/door where you put toner,lift the green handle up,push green lock towards the right side while pulling the hopper out,then theres a connector beneath the PCU,pull it then pull out the PCU,use the same same procedure to put it in,start with the PCU,return the connector and put in the hopper,then close all doors/covers
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Flase door open reading on my aficio 350. The door is shut. The machine is showing that the door is open but it not. It close as it should be.
when the door closed it actually activates the switch. see on the door if any plastic piece from the frame is broken or not and locate where in the machine does the front cover activates switch. it will be easy to find the broken part.
2answers
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
2helpful
Canon pixma mp 780
check out these sites
http://software.canon-europe.com/
or
http://driverscollection.com/?H=PIXMA%20MP780&By=Canon
dont forget to vote!!!
FixYA!!!!
old marine
old marine
ZJ Limited
ZJ Limited
