Question about Fisher and Paykel GWL11 Top Load Washer
My GWL11 won't fill correctly or wash!
I hope you can help me as I have a MOUNTAIN of laundry that I can't wash! My GWL 11 will not fill correctly 90% of the time. The water only comes through the little openings and will not gush in through the side likes it's supposed to. It will try and fill this way for quite a while and the the buttons start to light up and beep. The first wash button, and the hot and cold water buttons light up. If I try and fast forward the washing process it does the same thing. I have to finally go to spin to drain the washer. I cleaned out the washer today and unhooked all the hoses and blew through them and found nothing. Then I washed an empty load and it worked. I just tried to wash another load of clothes and it kept doing the same thing. Please lend your advice! Thanks so much!
Brandy
  • 70 Answers
Hi there you need a new cold valve in the washing machine. :)
Posted on Sep 21, 2008
As soon as water begins to fill the tube, water exits out the drain pump and drain hose. F/P GWL 11.
Is the drain hose too low? The drain hose needs to be higher than the top of the agitator , then curve over into the outlet pipe or basin.
Oct 25, 2013 | Fisher and Paykel GWL11 Top Load Washer
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL 11 is getting the error code 37. Checked for blockages, none found and pump operates normally, no sounds, impeller turns freely. Still will not drain in spin mode. Any suggestions?
Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
111 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
