Question about Mitsubishi WD-73833 73" HDTV
+little white star like dots all over my 73" mitsubishi tv. i replaced the buld but still have white dots, getting worse. what to do? tv is 3years old
  • thomas davis Oct 18, 2012
    the so call dlp chip is bad...mitsubishi wiil pay for part. need to pay for labor ....18003322119
It is the Optical lamp board
Posted on Jan 05, 2012
    New Friend:
Little white dots
Posted on Jan 03, 2013
    Filmmaker:
    Uploaded 5 video answers.
  • 18 Answers
Need to replace a new DMD Chip for your Mitsubishi TV. A post show where to buy a new replacement DLP chip and how to replace it only cost $159. Check for the post
Posted on Feb 23, 2013
  • Alex Ts Feb 23, 2013
SOURCE:
SOURCE: developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Posted on Mar 20, 2010
  • 8909 Answers
SOURCE: I have a Mitsubishi TV
You have failing pixels. The screen is not woking as it should but having said that there is a tollerance allowed by the manufacturers, dependant upon possition.
Sanyo, with their LCD Projectors had a formula to work the problem out, I will not share that with the world as it may give issues later on.
There wer however, a few pixels allowed before a replacement screen was ordered whilst under manufacturers warranty.
Basically, if it gets too bad, as it is out of warranty I presume, a replacement Screen or a replacement set will be reyuired.
Posted on Nov 01, 2010
  • 2920 Answers
SOURCE: Blue dots all over screen and getting worse
dead pixels you need to have it looked at
Posted on Jan 04, 2009
  • 91 Answers
SOURCE: I have a 3 year
I hope this helps please rate that it helped you so i know it did. thanks
  1. Turn off your monitor.
  2. Get yourself a damp cloth, so that you won't scratch the screen.
  3. Apply pressure to the area where the stuck pixel is. Try not to put pressure anywhere else, as this may trigger the creation of more stuck pixels.
  4. While applying pressure, turn on your computer and screen.
  5. Remove pressure and the stuck pixel should be gone.
This works because in a stuck pixel liquid in a subpixel has not spread equally. In combination with the backlight of your screen, this liquid is used to allow different amounts of light to pass through, which creates the different colors.
Should all of these approaches fail to fix your pixel warrior, at least you'll now know it's not simple to fix and the LCD may indeed need to be replaced. But please do let us know if these tips helped you to fix your pixels. In any case, good luck!
if this didnt work try the other four steps located in my tips and tricks page here:
http://www.fixya.com/support/r7629076-fix_dead_or_stuck_pixel_lcd_screen
Posted on Jan 04, 2011
  • 8457 Answers
SOURCE: just paid to replace the
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Posted on Sep 04, 2011
Is there a recall on the mitsubishi dlp chip wd-65735 and are they replacing them free
Nope,,,White dots, white snow or sparkling stars on your DLP TV mean only one thing - a worn out DMD chip. The white dot syndrome seems to happen when the DLP TVshave been in use anywhere from two to five years - usually when the warranty has expired
Certain brands seem more vulnerable than others to the white dot syndrome. Samsung and Mitsubishi DLP TVs have been plagued with the problems for several years now. Sony and JVC choose to take the TVs set off the market in response to complaints from disgruntled owners.
If you read the various forums offering solutions, you'll see customers being given quotes of $600 and upwards for solving the white spot syndrome or replacing the DMD DLP chip. Fortunately, there are companies offering the offering the DLP chip for under $230 if you want to fix it.
Dec 31, 2017 | Mitsubishi Televison & Video
How to replace chip on Mitsubishi tv to fix white dot problem
Here's a link on to replace the chip on the DM board.....tks.....https://www.youtube.com/watch?v=JgiZdc4kZDw\
Jan 31, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
My Mitsubishi WD-73737 73 in TV has white dots taking over the screen
Bad DMD chip
call Mitsubishi, they will send one to a servicer at no cost, you will only pay for labor
Sep 19, 2014 | Mitsubishi Televison & Video
Mitsubishi projection tv has white dot in it
most likely the DLP chip. this is not available for all Mitsubishi DLPs.If not you will need light engine replaced. If that's the case replace TV with LCD or LED TV.
contact local servicer to see if they can give a quote over phone. Be sure you are sitting.
Jul 23, 2014 | Mitsubishi Televison & Video
I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Sep 27, 2011 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
White dots on screen
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
2 little white dots on my lcd screen
if this is a DLP tv, white dots mean a light engine going bad. It will soon look like night stars in the sky.
Jan 16, 2011 | Mitsubishi Televison & Video
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-73833 73" HDTV Logo
628 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
