3253H /and other /coil/you are correct/coil
I own Samsung LNT- 2653H makes a high pitch noise when it warms up( you can really hear it when the LCD TV is muted!
noticedit after only one weeks of owning it ...now at repair ...tec didn'thear the sound himself...he did call Samsung they said it was a coil inthe power supply circuit /like you said
so it is a known issue /manufacturer defect/ but Samsung won't tell you anything when you call/ says there isn't any known recall on this tv...that is all they saybut they did tell my repair guy what the issue is
There are many Samsung LCD tv's out there with this issue especially the
LNT-2653H model
What would be the charge to fix this problem?...I am just curious?
I HOPE IT IS THE PROBLEM AND IT WILL FINALLY BE FIXED.
Can you explain what this part does?
Thanks
SOURCE: 42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
  • 50 Answers
SOURCE: Tv makes clicking noise but won't turn on
it is a power supply issue. options 1- replace the power supply
2- this unit has an issue with 4 capsitors on the power supply which sit side by side and are about 10 volt each replace them with standard 16v caps.
Posted on Mar 18, 2009
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
Posted on May 06, 2009
  • 21 Answers
SOURCE: LCD TV, No Power, No Standby LED, Buzzing sound from Power supply
sounds like either way your power board is bad- do you intend on replacing a component? I would look for Puffy caps- you know- leaking from the top-
Posted on Aug 21, 2009
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitched noise coming from back of Viore LC32VH56A. Not speaker related.
A refurbished set!
Its a coil or transformer that is not tightly mounted or is vibrating hard enough to make the sound, If this is a refurbished set that is why it was returned and exchanged-----
Two ways to fix---locate which board is bad and correct the problem with Hot glue on the individual part making the noise OR just replace that board.
Dec 08, 2012 | Viore LCD32VH56A 32" HD LCD Television...
Hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
Aug 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung LNT3253H is making a high-pitched noise
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Mar 22, 2008 | Televison & Video
Samsung slimfit television 30"
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Aug 11, 2007 | Samsung TXM3096WHF 30" TV
Hum on tv
Your problem is very simply. You have a bad ground. You need to purchase a plug adapter. The AC cord you plug into the wall. Must change from a 3 prong to a 2 prong. You can get this at the 99 cents store.
Best regards
CircuitCity
Nov 20, 2006 | Samsung LE32R41BD 32 in. HD-Ready LCD...
High pitch noise when tv warms up
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Sep 12, 2006 | Philips 55P8241 55" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
