Question about Xerox Phaser 7300DN Laser Printer
Tonner is not getting fused.
When I print anything the toner does not melt. There is just dust on the paper. if I turn the printer on and off I start working for a little while and then it start all over. I placed and old fuser I had and the same thing happens.
Any suggestions
  • Anonymous Oct 02, 2008
    I have a very similar problem with our Xerox Phaser 7300. Our problem is that the fuser dies very prematurely. It dies when it consumes 20% of the fuser (ie 80% STILL LEFT!). If we replace the fuser with a new one, it works just fine till it consumes 20% (about every 3 months it dies). Xerox wants to charge us $1000 to come out and fix it. I don't think it is neccesarily worth it. My guess is that we have a failing circuit board and some other glitch. Any thoughts anybody?
  • nigel99 Apr 12, 2009
    I have a similar problem. The 7300N can print a few pages that fuse normally then print a few that dont fuse at all, then a few that do. This can happen within the space of 30 seconds or so. I wonder therefore if its to do with heat as the fuser is clearly getting hot. I have examined the fuser and there appears to be a big gap between the top heated and the bottom 'pressure' roller. Is this normal ? Could it be that someting is not activating to press these together as the paper passes through? If so what ? I am loathed to buy a new fuser as the posts above suggest this doesnt help.
    President:
  • 2,072 Answers
You most likely have a bad main board in the machine. It is warming up properly , but once warm it is not pulsing the heat rod to maintain temperature. If you just walk away for a while, does the machine finally produce a fault code?
The problem is in the circuit that maintains the heating elements. Once it gets so cool,it should fault out.
You could have software corruption and its mainting to low a temperature. Let me know if after sitting for about an hour , is there a fault code that shows up.
Posted on Sep 17, 2008
Tonner Is removing from Paper
the fuser unit may be the cause. If paper is not warm after printing the fuser is not heating the paper to fuse the toner to the paper.
May 04, 2016 | Toshiba OEM ESTUDIO455SE 45 PPM...
Printer prints out but all powdery and wipes of page .
I agree the fault is almost cetainly with the fuser unit.
Oct 30, 2011 | Samsung CLX-3170FN All-In-One Laser...
I JUST BOUGHT A SHARP AR-5127 COPIER..WHEN IT COPIES, IT BRINGS OUT BLANK PAPER. I REMOVED THE CATRIDGE AND IF I TURN IT UPSIDE DOWN,SOME BLACK DUST COMES OUT...PLEASE SOMEONE HELP ME
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
mvincentc
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a aficio mp c4000 printer/copier. it is telling me the waste toner bottle is full. where is the waste toner bottle?
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
Mar 09, 2011 | Ricoh Office Equipment & Supplies
I have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges.I changed all toners with new HP genuine.still printer...
Normally that works when toner is real low. But if you are doing that with good toner levels then it may be humidity in the room making the toner powder clump or stick.
Have you performed a clean cycle/test. You may have problems with a fuse roller but that would be a longshot thing to check for.
Mar 23, 2010 | HP LaserJet 4700 Printer
Paper jams, remove toner put it back then restart printer!
May be the rubber rollers are coated with dust
Clean it and try after it dries.
(Plz do not use 70grammes papers)...use 80g
Feb 06, 2010 | Brother HL-2070N Laser Printer
All the lights started flashing after fixed a paper jam
you have take out zamed paper from the printer from the back side of the printer by ejecting the try from back side if it present. or pull out your tonner and then pull out the zame paper.
Aug 22, 2009 | Digital Products Brother HL-2040 Laser...
Prints dry colour powder on paper
You aren't fusing (melting) the toner to the paper. The probable cause for this is having the "envelope feed" levers in the "envelope", or up, position. This leaves a wider path for the paper, which does not allow the toner to be fused onto the paper properly.
The envelope feed levers are the two small green levers at the rear of the printer, one on each side, that are visible when the printer's top is lifted.
Dec 16, 2008 | Xerox Phaser 6120/YN Laser Printer
The printer is printing lines across each page (usually one of each toner color, sometimes only black)
the toner cartridge is near to empty so the powder collected on the wastage side is getting leaked when ever you give a printout and that leaked powder creates a line on the paper. or there is a dust collected in the lower area of the printer by the leaked tonner. replace the cartridges or get refilled it properly.to make this problem clear.
Nov 17, 2008 | HP Office Equipment & Supplies
Hl 2040
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Jul 27, 2008 | Brother HL-2040 Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
