Question about HP PSC 1210v All-In-One InkJet Printer
Paper run thru without printing
Sometime you hear it running back in fourth .
  • baver Sep 19, 2008
    it will print on notepad, but not on the internet,
    Novelist:
  • 217 Answers
Empty or dried up cartridge(s) ?
The carridges supplied with printers when new have very little ink (or toner for laser printers) in them. Some will print as few as 500 pages !!
Posted on Sep 17, 2008
Paper jams after printing 1/3 page. continue s to print on on wrinkled paper until file is totally printed
The rollers need cleaning. Office supply stores carry cleaning paper. It's sticky on both sides. Run it thru without printing on it. That should fix it.
Jan 24, 2014 | Epson Stylus Office Equipment & Supplies
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
Sep 09, 2009 | Epson Stylus C120 Color Printer InkJet
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Got MP130 series printer. Was working alright up till now, now paper goes right through without stopping and not printing anything.. When it does occasionally print, the writing is blurred and not...
My did that all the time too, but I always ran it thru the clean the rollers maintance the canon has on its driver, Did it three times then ran heavy grade of stock paper in thru there and almost always lint, dog hair, or whatever was in there comes out on the stock paper then it runs good again. ladytstarlight.
Apr 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Wont stay running
Check all things airflow related. The PCV valve, the air cleaner, the mass airflow sensor and any other filters.
Dec 01, 2008 | 2002 GMC Sierra
Out of Paper message?
Solution:- Complete the following steps in the order provided. Step one: Reset the product Without turning the product off, remove the power cord from the back of the product. Wait 30 seconds and then plug the power cord into the back of the product. If the product is not already on, use the On button to turn it on. Step two: Check the condition of the paper and reload it Replace any paper that is ripped, dusty, curled, wrinkled, or bent. Note :- Use only plain, white, unused paper in the product until the issue is resolved. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed. Tap the stack of paper on a flat surface to align the edges. Make sure that the stack of paper to be loaded in the product is no smaller than 10 and no larger than 25 sheets of paper. Note:- Do not load too much paper in the product. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step. Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays. Open a document in the program being used to print. Click File , click Print , and then click Properties . The product Properties dialog box appears. Click the Paper/Quality tab. Choose the appropriate paper size from the Size is drop-down menu. Choose the appropriate paper type from the Type is drop-down menu. Click OK and then click OK again to print the document.. If the issue is not resolved, continue with the next section. Note:- If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: If necessary, obtain the HP Paper Feed Cleaning Kit Locate the serial number on the product. If the third and fourth digits of the serial number are 56, 57, 58, 59, 5A, 5B, 5C, or 61 , then use one of the Contact HP links on this page to contact a support representative. If the product is still under warranty, the support representative will send a free HP Paper Feed Cleaning Kit (part number c9000-67901). If the product is no longer under warranty, this kit can be purchased from HP online. Click here for region/country ordering information. Figure 1: Serial number with third and fourth digit circled c00743072.jpg If the third and fourth digits of the serial number are not listed, the special cleaning kit is not necessary. Continue with the next step. Note:- The HP Paper Feed Cleaning Kit requires the product to be connected to a computer running Windows 2000 or XP with a USB connection. If the product is not already connected with a USB cable, connect it before using the HP Paper Feed Cleaning Kit.
Oct 23, 2008 | HP Photosmart C5180 All-In-One InkJet...
Does not print
The CX series printers use a pigment based ink, and if it dries it frms a semi hard gooy substance on the printer ink input pins.
Sometimes after the insertion of new cartridges (Ensuring the yello tab is removed) and letting them sit overnight (to soften the ink blob) and running several cleaning cycles can unblock the ink "jam". Note: Epsons printer head need ink to cool them when printing (Sort of like oil in a car) so don;t try to print withot having ink flowing to the heads. It can also ruin the print head by overheating.
If all else fails there are several companies that sell inkjet cleaning solution. You may need a couple of cartridges to flush blocked jets but if will most likey work if the print head is still functional.
Otherwise, the technican is correct, you may need to purchase a new printer.
Note; For the future... Never let the ink run out of any cartridge without immediately replacing the cartridge. Never remove an empty cartridge without replacing it immediately.
May 21, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Paper jam
can u see any part of paper anywhere in paper ,usually it gets stucked on the back side in the fuser assy ,remember dont try to remove any paper with any metalic tool even if u find any peice of paper
Jan 23, 2008 | Samsung ML 2010 Laser Printer
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
HP4 and PC LOAD LETTER MSG (and there is paper)
Hi, I assume you can run paper thru the manual feed without any problems? If so the paper sensor that detects the paper in the tray has either broken or fallen off! If you take the paper tray out and tilt the printer a little bit on it's back you should see a sensor that will swing back and forth its' solid black/plastic . The sensor is very cheap and I'm pretty sure this is the problem> Good Luck!!
Nov 29, 2007 | HP : HP4 Laserjet Printer
HP PSC 1210v All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
