Reply to post on my Hitachi HD tv
The black box on my tv is not there when i play a dvd or when i play the xbox 360. I have the same cable wire running to all the tv's in the home and only this tv is acting this way.
Thanks,
Cassie
  • jenncassdave Sep 17, 2008
    I have no teletext messaging button on my remote and i have checked in the main menu. I have no idea what is wrong with this stupid tv
  • 10,594 Answers
Well, then its problem of TeleText Message option in tv. Please find TeleText button on Tv remote and press it to Off teletext function.
Posted on Sep 17, 2008
  • Shahid Electronics
    Shahid Electronics Sep 17, 2008
    Teletext usually mentioned in 3 different color buttons on remote. Kindly mention your tv model to see teletext buttons in its user manual.
My x box will play cd's and dvd's but not games. do you know what i can do to fix that. when i put in a game it says to put disc in an x box 360 console.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game. Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Mar 10, 2010 | Buck Legendary: The Box for Xbox 360
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
