Question about Sharp 27SC260 27" TV
Sharp 27sc260 27"
Tv was working fine then turned on and whole screen is blue
  • 1 more comment
  • thilbert1 Sep 17, 2008
    I,am sorry the model is sharp 27r-s50 27" color w/remote hooked to cable
    I do not have a cable box hooked directly to tv. I hooked another tv to it and worked fine.
  • rich medrano
    rich medrano May 11, 2010
    Well I think that yoru TV is not getting a correct input. Would you discribe what is feeding your TV. Cable, DirectTV, etc. also there may be a problem with the TV's menu input. Would you provide more info as to the TV model?
    Scholar:
  • 188 Answers
If you have a cable box you could bypass it to make sure it's not the cable box. It could also be the input to the TV channel has been changes so as not to be on the right channel from the cble box. Is the TV on channel 3? Or video input? and did you change anything that would have caused this in terms of cabling? If not it seems to be a TV menu issue we would hope.
Posted on Sep 17, 2008
  • rich medrano
    rich medrano Sep 18, 2008
    The manual can be downloaded here. Starting on page 40 there are some tips to trouble shoot you issue. You will need the Adobe reader program which is free and can be found easily via a web search. Good luck.
    http://www.sharpusa.com/files/tel_man_27...
My sharp aquos has gone to a blue screen and message saying not supported, why has it done this?
Suddenly it is plugged into what? The TV only works when a signal is sent to it. The TV is probably fine, but of course it's the messenger. Must be where the problem is.
May 04, 2014 | Televison & Video
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
My Sharp AQUOS LC-40C32U's video goes away seconds after turning it on but the audio stays so in other words we can hear it but we can't see it. Why?
This issue is normally caused by a transformer going out on the inverter board. The inverter board is in charge of turning the backlight on and off. When you have a component (Transformer) on the board go out, it will cause the whole board to not respond, the rest of the TV works fine which is why you still have audio and can most likely change the channels and act as if the TV is working fine with the exception of course that you cannot see anything on the screen. The board itself is very easy to replace there is no soldering required (unless you try to fix it to the component level) but in most part it is better to purchased the whole board and just swapping it.
Oct 05, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Whole Screen Turns Blue in seconds....
This could be a problem with the Blue CRT it archs or overdrives intermittently. I would have a technician test the set and give you an estimate - if it's the CRT it's usually not worth repair- but it could be video or a screen voltage related problem. It's worth the estimate.
Oct 31, 2009 | Sony KP-57WS520 57" Rear Projection...
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Blue screen
The blue picture tube has gone bad. Sadly they are no longer availible for that unit. But the blue tube assembly can be sent back to a company called Video Display. They rebuild the tube for a very reasonable price. The hitch is that it takes a professional tv tech to reinstall and align the rebuilt tube. Most respectable shops will do this work but the repair is spendy. Usually around $450 to $500 or more.
May 13, 2009 | Sony KP-51WS500 51" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
Sharp 27SC260 27" TV Logo
99 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
