It is difficult to get the check for reuse. It can be located. If the printer is not flashing signal of paper jam then take a test print on A4 size from the printer with full page matter. If you are getting this print with smears in particular area of the paper then you can be sure that the check is wrapped around the fuser roller/film inside the fuser assembly. The fuser assembly is located at the rear side of the printer which will be visible only after opening the back door/cover.
