Question about Apple iPod touch
Ipod touch 8gb
Alright, i have an ipod touch and it wont recharge the battery. it got really low and is saying 'you have 10% battery life left' or summat the like so i plug it in, the big battery comes up with a smidging of redness but nothing. i have left it for hours and nothing. i have tried keeping my finger on the top button and then the home button so that the apple sign appears as suometimes this kicks it back into life, but nowt. can anybody hel ?. i have tried a couple of leads and a couple of computers and nowt
cheers
jonathan
  • 1 more comment
  • National117 Nov 30, 2008
    Yea I have a problem I pluged in my iPod and it's not charging, so I tried to unlock it, I enter my password and nothing happends. What to do. I can't turn it off, I held down the button and it won't turn off. This is bad
  • Scorpy Corky Dec 11, 2008
    Yup, same here guys. None of my ipod chargers work.
  • MrsCurrie May 24, 2009
    Husband's iPod Touch is useable if plugged in, but does not charge. It stays at 20% no matter how long it sits on a charger. We thoguht it was originally HIS PC... but we tried it on MY PC -- and it still does not charge.
    The suggestion someone posted about clicking the off/power button and the home button at the same time will reset it --- do NOT work for my husband's.
    Anyone having any idea of how to fix this OURSELVES - please post up!! Thank you!
    ~~Mrs. Currie~~
I ran an apple USB lead from my Mac Book to my iPod touch with i Tunes running and that did the trick.
Posted on Dec 11, 2008
  • 3 Answers
What you do is hold down the sleep button and the home button at the same time till the screen goes black then it will restart and it should work again.
Posted on Dec 15, 2008
Wont turn on after reset
The iPod Touch has a battery capable of up to 40 hours of audio playback, but depending on how you use your iPod, the battery capacity can vary widely. If you attempt to turn your iPod on and get no result, the battery could be fully drained, which you can easily resolve by connecting it to your computer to recharge it. If this doesn't work, resetting or restoring your iPod may get it working once again.
Charge Connect your iPod Touch to your computer using the USB cable that came with it and charge it for at least 10 minutes before attempting to use it again. If the battery is fully drained, the screen may remain blank for a few minutes after plugging it in, and then a low battery image will appear, indicating that you shouldn't unplug it for at least 10 minutes. Never plug your iPod into your keyboard, but rather into the computer itself. Also make sure your computer is on and not in sleep mode while your iPod is charging, or the battery may drain rather than charge. Reset b> If recharging your iPod doesn't resolve the issue, reset it while it remains connected to your computer. Push the "Sleep/Wake" button and the "Home" button simultaneously until the battery symbol or the Apple logo appears. This takes about 10 seconds. Continue to charge your iPod if the low battery image appears after the reset. Restore b> If your iPod Touch still isn't responding, restore it in recovery mode. First, place your iPod in recovery mode by disconnecting it from the USB cable, and then press and hold the "Home" and "Sleep/Wake" buttons simultaneously until the iPod turns off. Push the "Home" button once again, and continue to hold it while you re-connect your iPod to your computer using the USB cable. Continue holding the "Home" button while the iPod turns on and release it only when the "Connect to iTunes" screen appears. Open iTunes, and click "OK" when the recovery mode alert appears. ITunes will restore your iPod back to factory settings. You'll be able to sync it with iTunes to recover the data you lost during the restore, provided you have synced with iTunes in the recent past. Check Liquid Contact Indicators b> All iPods manufactured since 2006 have built-in liquid contact indicators. If your iPod has been in contact with liquid, this could be the source of your problem. You can check whether the liquid contact indicators have been triggered by looking straight down the headphone jack on your iPod. If you see red or pink at the bottom of the headphone jack, your iPod has been in contact with liquid, and this is likely the cause of its malfunction. Contact an authorized Apple repair center to inquire about whether a repair is possible. Such repairs aren't covered under your iPod's warranty. iPod touch: Hardware troubleshooting http://support.apple.com/kb/ts2771 iOS: Unable to update or restore http://support.apple.com/kb/HT1808
Apr 13, 2013 | Apple iPod touch
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
When I Connect My Ipod Touch 8gb To My Computer It Wont Turn On And I Didnt Charge It For Like A Month What Should I Do Please Help Me!!!
You are right, it doesn't have enough power to turn on because the battery was drained. You're saying that it wont charge? It could only be the USB cable problem. Try to use a different iPod USB cable and check if it charges the iPod. Another thing is try to charge the iPod using the stand alone USB charger. Your iPod requires high power input. If that doesn't work, you may start to think that it is a battery failure.
Feb 03, 2011 | Apple iPod touch
Alright so my ipod touch was dropped in cedar water and was working fine after i let it dry then the next day it is not working at all it wont turn on and the computer doesnt recognize it anymore PLEASE...
it probably is one of 2 things. The battery shorted out or it actually caused water damage later on that night. Downside to apple products is you cant remove the battery when they get wet almost guaranteeing damage. Best thing to do is to send it to a repair center such as this one. They guarantee there work and can fix about any problem that could have arised, but even if you just got it and it may be under warranty apple doesnt cover water damage.
Jul 12, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
8GB apple ipod touch
well you can conpleatly restore it by not pluging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Aug 04, 2009 | Apple iPod touch
My 8GB ipod touch is disabled
You need to put in DFU MODE, and restore your ipod touch.
Easy:
Press The Home Button + power button for 10 seconds. after 10 seconds, press only the Homme button.
And now, connect your ipod touch on itunes and press RESTORE.
Jun 28, 2009 | Apple iPod touch
Ipod nano 8gb Low battery Life
Umm i have heard that you are supposed to charge completely before you use them, also the more you charge it when it is low the less life it will have...
Jan 08, 2009 | Apple iPod nano
I pod touch
ipods are only designed for itunes so windows shouldn't recognise media player, any way, the new software for ipod touches is greater, meaning your computer/windows media player wont recognise it, only itunes will.
Cheers
Oct 18, 2008 | Apple iPod touch
Apple iPod touch Logo
182 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
