I have a Toshiba tv Model MD20F51 which turns on for several seconds and then turns off,no picture.
  • tucker22244 Sep 17, 2008
    what other possible causes are there?
  • 1,800 Answers
This problem occurs when the ignition circuit/chip is faulty.
this one is the repsnsible part of tv that gives to the TV to start/turn on TV.
its located on the motherborad of ur TV u can replace it but first u need to locate it its near to the voltage transformer just follow the electric jack cable and u will find it
and its need a serious soldering skill!!
best regards if u u need further help ask me!!
plz do rate this post if u can.
Posted on Sep 17, 2008
    Sergeant:
  • 399 Answers
Normally this problem is caused due to loose capacitors on the powersupply.also check if the capacitors hve bulged up .if u find them bulged then replace them .it should solve ur problem.
for any further queries feel free to ask.
thanks
  • masterexpert Sep 17, 2008
    for the problem u discussed the only possibility is the faulty capacitors according to me.
  • 171 Answers
There are a couple of things that can cause this problem. First thing to do is try and find the two big power supply capacitors marked C809 and C810. Make sure that the negative side of these capacitors is not loose and unsolder ed. If one of them is, resolder the lead and replace fuse F860. If this does not look like this is the problem, unsolder the convergence IC's and see if this is the problem. Most of the time though the IC's are shorted and both has to be replaced as a pair. Good Luckng to be a
  • Todd Gale
    Todd Gale Sep 17, 2008
    Try resetting the lamp timer. Unplug the projector, hold the menu, on/standby and input buttons, and plug the projector into an outlet. The 3 main lights should come on and stay on (on/standby, lamp and another one).
    Then unplug and replugged the projector. It should power up.
  • 55 Answers
Hii :
sir
. it is the integrated circuit ( Is a technical problem related to one circuit necessary to smoke to a
technical specialist in televisions ) ..
  • 2,326 Answers
The problem could be related to a high voltage shutdown cause by a failing or defective power supply and a horizontal deflection failure.
This failure is not a DIY due to the danger of working around high voltages is excess of 30Kv.
One line horizontal onscreen
This is well known problem with the Toshiba line, the problem is in the vertical deflection circuits, it causes the picture to collapse to a flat white line, the vertical output ic and two to three capacitors need to be replaced to correct the issue.
Jan 19, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
How do you remove text from your tv screen
I am assuming it is the closed captioning that is showing... should be a menu item to turn of CC ('Closed Caption') or SAP (Second Audio Program tends to be bilingual and not CC).
Peace,
Mar 07, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba D.l P
the solution is that your web site isnt actually FREE...........
Aug 01, 2009 | Toshiba MD20F51 20 in. TV/DVD Combo
Black Box on screen
By your description it sounds as though the closed captioning option has been turned on on the TV. Only certain programs are CC capable and that accounts for the box moving from channel to channel as some broadcasts are not CC CAPABLE. Go to the menu on the tv and ensure closed captioning is disabled. This should resolve the issue. If you need more help please let me know.
Oct 06, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba TV/DVD combo = Model #MD20F51
i don't understand what happen to you. Try to explain very well.
Jul 30, 2008 | Toshiba 32A33 32" TV
Tv Screen Turns blue occassionally while running Toshiba DVD player
If the flashing is regardless of source, the CRT could be at fault. H to K short. ( heater to cathode)
Jul 23, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Locked tv/dvd
simply press and hold down the display button(located below the AV button) on the remote for 3 to 5 seconds and it will unlock .
Jun 12, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Power problem
A common failure in these units is Q401, Toshiba p/n# Bz510004 is a 2SA1624 (HV amplifier) which finally fails due to a resistor R408 Toshiba p/n# Bz210285 a .47 ohm/1w metal oxide having changed in value and at last opening...
This isn't an expensive repair for a qualified shop - but I would suggest not continuing to test your shutdown circuit. What's happening is that HV (high Voltage) is builds beyond tolerances and the shutdown circuit turns your unit off to keep from causing any severe damage. If it failed you could likely burn out the SMPS or cause some substantial damage..
Good Luck!
Bill
Dec 01, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
I'd like to add another on the power problem
Good Luck!
Bill
Nov 10, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
