Question about Samsung Televison & Video
Samsung LED DLP 50" has a green cast on entire screen on all inputs. It cycles to red then back to green. Customer adjustments no effect. I assume the light assembly needs replacement. Any guidance appreciated. Thanks- Joe Amaro San Ramon, CA
  • joeamaro Sep 17, 2008
    Thanks for the help. Comment; not everyone's a tech so a quick explanation on terms like 'blown caps' would help the layman grasp it in one sentence or less.
    Genius:
  • 2,920 Answers
You may have blown caps take it to a repair man and let them fix it so you dont jave to troubleshoot everything...they usually know right away what the problem is
Posted on Sep 17, 2008
  • Ronnie Houston Sep 17, 2008
    there are 4 capasitors in back of the tv one on each corner if they are popped up istead of flat that means they have popped...sorry i wasnt clearer on what i was saying.they are easy to spot too.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
I Have A Samsung DLP 61 Model HL-T6187AS and Serail- AHEK3CKPA01439H and It Has No Red What Could Be The Problem
Most likely problem is the Red LED (pt# BP07-00023A, substitute BP07-00029A) $96.68 https://www.encompassparts.com/item/7806544/Samsung/BP07-00029A/Led_Display-red
OR http://www.shopjimmy.com/catalogsearch/result/?q=BP07-00029A
& or the LED driver board (pt# BP94-02321B) $170.00 includes core https://www.encompassparts.com/item/7696533/Samsung/BP94-02321B/Assy_Pcb_S-led_Drive
Don't forget that if you are using component input cables it could be your Red input line either faulty cable or not plugged in all the way on either end.
Oct 03, 2011 | Samsung HLT6187SAX 61" DLP HDTV
The entire picture area has a green tint. Adjusting the red/green levels doesn't help . The problem seems to have happened overnight. We were watching it yesterday and everything was fine. Now everything...
How old is your lamp? This isn't likely the problem, but they do tend to go out over time. This could also be related to the colorwheel motor going out or the DMD board sending a faulty signal. I would suspect this to be about a 200-300 repair. The diagnosis process is going to be hit and miss. How attached to the tv are you? :)
Jul 27, 2009 | Samsung HLM617W 61" Rear Projection...
Picture is in reds and greens
Try doing a "factory reset". This will "burp the baby". Turn the set on and ignore what you see. From the side control panel, push the volume+ and channel+ buttons in synch. This will take you to a base OSD (on-screen display) that can best be compared to the BIOS on your PC. The real goodies are here.
On the OSD, you'll see "picture", "audio", and "advance". Using standard navigational input on the remote, go to "advance". Tab down to "clear all". The set will appear to turn off, but the front LED will remain blue. The set is re-formatting the on-board memory and will restart in a few seconds.
Your panel should now restart as normal, but will be returned to factory "burn-in defaults". Your color and audio adjustments will be lost, so you'll have to do some fine-tuning in the regular OSD menu. Cycle power to the TV after you have made the desired adjustments.
TIP: Perform the factory re-set a second time, then select "picture". Toggle down to "video format". You might find it set to "Pal". Change this, using standard navigational input on the remote, to "NTCS" or "AUTO". Cycle power to the TV after you have made the desired adjustments. The TV will now perform at a refresh rate of 60hz, the American standard. "Pal" is 50hz, the EU and Asian standard. The improvement to image quality will be noticable very soon, as both your eyes and the set adapt to 9.94 hz improvement. NOTE: You may need to fine-tune the TV again after making this change.
Mar 21, 2009 | Polaroid FLM-3732 Television
53UWX10B
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
130 people viewed this question
Henry  Thomas
Henry Thomas
