Question about Zanussi Washing Machines
Change pump on zanussi fl1055w - Zanussi Washing Machines
    President:
  • 1,462 Answers
Tilt machine back at a good angle. i find it easier to remove the three screws round the periphery of the pump motor holding it to the pump houuuusiung. it is a fiddly job at the best of times
Posted on Sep 18, 2008
My zwf 16581 w zanussi shows E32 error code. I have replaced the pressure switch but nothing has changed. Please help
If you are replacing an analogic pressure switch and nothing has changed I suggest you the following:
  • Drain the water from the tub.
  • Are pressure switch hose and air trap system free? (You can disconnect the hose and blow in it to check if the system is free).
  • If YES, than check the draining system (filter, drain pump, drain hose). Is the machine draining correctly?
Dado
Feb 23, 2016 | Zanussi Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Changing drain hosezanussi w1242w
It clips onto the pump , you undo the clip remove hose refit and reclip same checking for any leaks before running machine, its very simple to do .....
Apr 13, 2010 | Zanussi W1242W Front Load Washer
Zanussi Aquacycle F 1045W doesn't drain
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Zanussi IZ12 Front Load Washer
My zanussi aquacycle 1000 will not drain and pump is making funny noise have already taken hase going in and coming out of pump off and cant see problem
the pumps do go duff. you can take the pump of and try it with a 12v supply if the blade goes round free is kk but if it stugles to move you need a new pump you can get them off ebay for a 10er
Jun 28, 2009 | Zanussi F1045W Front Load Washer
Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
Jan 01, 2009 | Zanussi FS1455W Front Load Washer
Drain pump FJ 1454W
Prob sorted, phoned Zanussi service enginneer
Nov 13, 2008 | Zanussi FJ1454W Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
