Question about Vacuums
I cannot switch vaccum off!!!! - Vacuums
  • 120 Answers
If its a hoover then take it to a repair center and have the switch replaced they are known to do that.
Posted on Sep 17, 2008
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
I need an part ... for the vaccum i need the piece that turns the vaccum on the switch .....
Sorry to read about your problem, I hope this helps you out.
you have to contact Numatic
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Numatic WV370 Canister Vacuum
The system was turned on manually to vaccum out the car and now the only way to turn it off is to unplug it (i.e. pressing the switch on the vaccum canister to auto from manual does not turn it off). Bad...
It is possible that it is a bad switch/circuit board on the unit. If your unit is less than 7 years old that should also be covered by warranty (manufacturer) however an in home service, should you require someone to come to the house will not be covered.
Nov 03, 2010 | Beam Industries 2775 Serenity Plus Central...
My vaccum cleaner will not turn on...i checked the outlet and it works but no power to my vaccum
Some vacuums have a resettable circuit breaker in case of overload or switch in case of blockage. Both are usually a pushbutton type thing (like on a powerstrip). Find it, reset by pushing, and run the motor. Check for obstructions and for anything that could be preventing the brush-roller from turning. If the breaker or switch trips again there is a problem that needs to be resolved.
The manual might be helpful.
Oct 08, 2010 | Vacuums
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Switch is not working I want to change it but I cannot access it.
THE LONG PLASTIC STRIPS DOWN THE SIDES HAS A TRACK IN IT. YOU MUST OPEN THE DOOR AND PULL (SLIDING) THE STRIPS OFF THE TRACK LONG WAYS AND THE TOP HALF WILL SEPERATE FROM THE BOTTOM HALF. BEWARE THE WIRING INSIDE IS JUST LONG ENOUGH AND CAN DISCONNECT EASY. IM PRETTY SURE YOU HAVE TO DO THIS TO GET TO THE BOARD INSIDE.
Mar 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vaccum just stopped working tried turing back on and nothing
Check and make sure that the bag emptor(bottom of bag asm.) is pushed up against the casing. There is a safety switch there that may not ne engaged. Cord may be bad, one side of the line may be open. Noozle asm. not on straight, there is another safety switch there. Problem with switch or motor.
Mar 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore vaccum cleaner
Switch number is 4369051 . You can go to sears.com, click on the parts link, put in the part number and you can order it thru them. Or put in you model number, click on dust compartment and a parts list and a picutre diagram will come up. You can order there also.
Mar 20, 2008 | Vacuums
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Ifix@shentel.net
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
49 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
