Question about Mitsuba DV55 Camcorder
DV55 will not power on
Have had the unit for a little while. The unit will not turn on. I have tried different batteries but nothing works. Any help would be appreciated.
  • Anonymous Nov 24, 2008
    push power on button lights on and then beeps and goes off
When I plug the USB cable in, It turns on to transfer files and can view pics on camera, but will not turn on to take photos / video.
Posted on Sep 17, 2008
I have a pioneer XV-DV55 and the center speaker and Left and Right rear speaker are not working. What should i do?
Did you check your speaker selection switch to make sure that those units are getting power? If that is not it I am afraid that you may have a problem with the dts audio chip responsible for the decoding of the different channels ..I had this happen with my Pioneer 9700 receiver.
If you have an amplifier module that powers certain channels see if there is an amp module that powers those three areas. If so, it could be THAT amp module that is defective since lots of newer receivers do not have discrete amps for each channel and resort to modules to supply power to two or three channels at a time ala Panasonic receivers.
Aug 27, 2015 | Pioneer Xv-dv55 5.1 Home Cinema System
Black screen and nothing else
Try unseating and reseating the memory one stick at a time in each slot one at a time and see if you can get video back that way.
If that doesn't work then go ahead and take the battery out and only hook up the AC Adapter.
If neither of these two steps work then the motherboard is bad.
Aug 04, 2009 | ASUS Eee 4G Notebook
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
I have a Pioneer xv dv55 . My sub or speakers are not working!
I've had mine for nine (9) years and it fine, first make sure all coloured wire are connected to the sub correctly, press sys on your remote then press button 8 to test if the speakers are working then increase the volume to hear the spaekers. so to link TV audio/sound with DVD press sys then A-2 on the DVD remote, I hope these will solve ur problem?
Jun 06, 2009 | Audio Players & Recorders
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Notebook will not power up no lights , nothing have tried different power supplies but nothing helps
I've had the same problem:You probably need to insert a new little 3V button battery. You find it under one of the little covers screwed underneath. Good luck - and work carefully. It shouldn't be a problem!
Lasse Rg.
Apr 07, 2008 | KDS Valiant 6380iPTD-01 Notebook
Sony ccd-trv68
Unit has circuit problems, have serviced
Apr 18, 2007 | Sony Handycam CCD-TRV68 Camcorder
APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
Mitsuba DV55 Camcorder Logo
59 people viewed this question
Top Mitsuba Video Cameras Experts
prouddad_1
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
