Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
I moved myfax to a different phone number and now i am not getting any dial tone on it.
I have checked the phone cable and it has dial tone. made a call from it via a handset.
What do i need to start from the scratch.
Thanks
Khalid.
  • 146 Answers
If there are two RJ-11 jacks on the fax machine you need to make sure that the line from the wall is plugged into the LINE jack not the TEL jack. If that is not it let me know and I will provide you some troubleshooting instructions from the factory service manual.
Posted on Sep 17, 2008
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 goes dead when I edit one-touch a/o abbreviated-dialing
You need to do a GLOBAL RESET. the machine will reset to factory defaults clearing ALL settings..
Function
7
press monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to initialize.
Feb 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Takes too long to send a fax, errors out
please tell whether you get to hear the ring tone and further to that fax tone on the other side or not?? then i can suggest ... happy faxing omnipresent
Aug 10, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
