Question about Gateway Computers & Internet
My computer comes on but my screen is blank - Gateway Computers & Internet
  • 208 Answers
Hi tytiyana..
i am giving my sugggestions.
Remedies. The remedies below should be performed in order. NOTE:Turn off the computer after each step. Never work inside the computer case with the power turned on.
1. Check and make sure all cables are firmly attached to the back of the computer and to all external devices. Retry.
2. Remove the case cover from the computer. Make sure all cables (hard drive, power cables, other disk cables) inside the computer are firmly attached.
Press down on all ISA and PCI cards and make sure they are firmly seated. Make sure your DRAM memory cards are firmly seated. Feel the top of the CPU and make sure it is not hot (warm is OK). Retry.
3. This step is only for newly built computers that have not successfully booted. Get out your motherboard manual, or download one from the manufacturer's site, and go over all your motherboard jumper settings.
Set the jumpers in the most conservative position. Review all your accessory wire connections (keyboard lock, hard drive access light, etc.) and make sure the connectors to the motherboard are facing the same direction. Retry.
4. Turn the computer back on with the case off. Verify that your CPU and power supply fan are running. If either one is not running you have a problem. If the power supply fan is not running replace the power supply (make sure the power connectors are correctly attached to the motherboard). Make sure the CPU fan is connected to power on the motherboard. If it is correctly connected and still doesn't run, replace it. Retry.
5. Unplug your computer. Remove all PCI and ISA cards. Reinstall the video card and disconnect the hard drive cable. Plug in the keyboard, video cable, and power cable. Restart your computer. If this worked, go to Step 6. If your DOS screen doesn't come up at this point try the following ideas.
a. Closely examine your motherboard and make sure it is not making contact with the computer case, which will short it.
b. Your video card, video cable, or monitor may be malfunctioning. Borrow a video card, cable and monitor, retry.
c. Remove and reinstall your DRAM. If your computer can not find system memory it will not POST.
d. Remove the CPU and reinstall it.
e. Follow your motherboard manual's instructions for resetting your BIOS to its default configuration.
If your computer still will not boot into a DOS screen, seek professional help.
Posted on Sep 17, 2008
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
Fujitsu amilo Si3655 laptop screen coming blank
It Sounds Like The Problem Is Caused By Settings For A
Screen Saver You Have Enabled! If This Is Correct Then
All That Is Needed Is To Ajust The Settings Or Disable It
Completely! See The Manual For Both The Laptop And The OS For Further Details!
Apr 02, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Screen keeps going blank
Hi Wendy,
Sounds like a faulty or loose component inside the screen.
It can be caused by many loose or faulty electronic parts. Best you take it to a repair shop to have it checked out.
Best wishes,
Apr 06, 2010 | Computers & Internet
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I sometimes get a blank screen while i'm using the computer or when i'm watching a dvd? why is the problem?
you may have screen saver active with no background selected, so when it goes to screen saver it only show blank scree. next time screen goes blank touch a key, if screen comes back, it is your screen saver, go to control panel find personalize and go to screen saver, make changes.
Aug 19, 2009 | Acer Computers & Internet
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
My screen is blank wont come up with words
Sounds like the ipod may be dead. When you plug it into the computer does it stay blank, nothing ever comes up on the screen?
Jun 25, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Computers & Internet Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
