Question about Sony BRAVIA KDL-40V2000 40 in. LCD Television
Sony kdl40v200 had sky install hd and they said that my tv had message on screen saying "this screen is not compatable with hd cp" Sky say its sonys problem and sony say its skys problem.
  • 325 Answers
I work for sky as an Engineer (not a subby)
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
Hope ive been of some help to you
Little Dish Fitter
Posted on Sep 02, 2009
  • Mick Sep 14, 2009
    There are several ways in which you can fix this problem.
    1: go to the sony web site and download the update for you television.
    Make sure its the right software for the television. ie type the serial number into the search banner.
    2: If you still in warranty with your Sky HD box then book a service call and get them to change the manufacter of the box. HD manufactours are as follows Thomson, Pace, Samsung, Amstrad
    I install Sky and have found this fault on quite a few sony bravia tellys either option will work for you.
    Hope this helps
    Little Dish Fitter
4 Suggested Answers
geordie rob
  • 7 Answers
SOURCE: Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Posted on Dec 29, 2008
SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Posted on Dec 31, 2008
SkyGuy08
  • 27 Answers
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
I have a sony mp3 walkman i can connect the usb to the side of my tv and it will play my music files etc but when i connect it next to the sky viewing card on my sky hd box it says no connected devices...
Sky put the USB ports on the boxes in case they wanted to use them in future. They are there but not active.
Bit like the eSATA socket on the back, it isn't used yet but they had ideas to use it!
I guess if they had to replace boxes all over the country to put a USB in would have been a bit of an issue for them, so best they fitted one from the start...
Nov 16, 2011 | Sony Walkman NWZ-B142 MP3 Player
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Is there HDCP chip in Sony KF-E42A10?
HD programing 1080i,if tv it can get that mode.No part change in tv to get HD it can or not, that it.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
To suppress the AV1 symbol on screen
on original sony remote press the DISPLAY button once
Mar 26, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony BRAVIA KDL-40V2000 40 in. LCD Television Logo
321 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
