Question about Fuji FinePix A900 Digital Camera
Camera wont come on
The lense came out and the camera shut off and will not turn back on. the battery is charged. could it be the battery? the camera is new
    Problem Solver:
  • 4 Answers
I had the same problem with the same camer you have to take it back to where you baught it and they should give you a refund or trade it in
Posted on Sep 17, 2008
Indian Guru
  • 32 Answers
SOURCE: camera shut off during photos and will not turn back on
camera is not not recoginising the battery may there be a battery type mismatch or battery type is not provided correctly in the software of camera
Posted on Apr 25, 2007
SOURCE: casio Exilim EX-S770
Step 1: Take the camera firmly in hand and bang the bottom part against a hard surface. A desk works really well!
Step 2. Take off the right side molding and blow compressed air (A LOT) in the bottom of the camera.
If it doesn't work repeat step 1 and 2 again.
I had this problem and now it all works out!
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
Posted on Jan 31, 2009
  • 256 Answers
SOURCE: Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Posted on Jun 11, 2009
SOURCE: My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Posted on Jul 15, 2009
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
I turned my camera on and the battery was too low so when it shut itself off the lense didnt go back in, now i've charged it and the lense is still stuck out. how to i get it back in so my camera will work
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
It wont stay on. when i press the power button the led light blinks red. the camera is off but the lens is sticking out
It looks pretty much as battery problem, try using a new and charged one. Low charged (bad)battery can do strange things to eletronics
Oct 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My camera won't turn on
Take the batteries out and leave overnight - put a fresh or fully charged set in See what jappens If still no go Get on to Sony Tech Support. If still under warranty -send it back
May 18, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
NEED HELP PLEASE
verify the battery is charged, this has happened to me. the battery dies without warning and the camera just hangs in its last state, usually with the lense extracted.
Aug 01, 2006 | Casio Exilim EX-Z750 Digital Camera
Fuji FinePix A900 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
