Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Suction All belts are working, the hoses are not pluged. I don't have any suction at all. Could it be the filter in the canister where the dirt goes?
  • 120 Answers
Absolutely all the air in a vacuum would pass through the filter and if its clogged badly you could loose all your suction and if the belt is more than a year old then replace it even if it isnt broken ( they stretch out over time )
Posted on Sep 17, 2008
No suction after assembly
Sounds like you have a tube misaligned. Take the tubes that lead to the filter off and put back on. Most likely the solution
Feb 13, 2014 | Dyson DC25 Bagless Upright Vacuum
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
No Suction ARGH!
on the backside you will see a clear type of hose towards the bottom coming up the back.thats your intake hosethats whats clogged.you will see a connector that its connected to.on the connetor there is a screw,take the screw out and pull the connector away from the cack.take a coat hanger and bend the end so its round and work it down into the intake hose ,you should be able to push the clog out through the bottom.be carefull not to puncture the hose
Mar 15, 2009 | Dirt Devil Featherlight Bagless Upright...
I have a Dirt Devil Vision and when I put a clean canister back in place the suction at the bottom of the filter clogs up and very rarely go into the canister. Also where the air blows out of the motor, I...
yes your intake hose is clogged thats the clear hose you can see it on the bottom from the back.disconnect the upper hose from your intake hose and try to push a coat hanger through with the end of the coat hangers end bent till its rounded so you don't puncture the intake hose
Jan 05, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Dirt is not going into canister
I have been dealing with this exact same problem for a week and has been driving me crazy! I have done everything you just did and nothing worked. I just took the filter out that is underneath the canister and when I did it was clogged up real bad with tissue, styrofoam and hair. I reached in there and pulled as much out as I could then got needle nose pliers to reach in there to pull out the rest. Remember, it's behind the filter, not the filter itself. My vacuum works great now!!!
Apr 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Hi, my sanyo pulse 1500 bagless vacuum has very little suction.
If the vacuum will run without the hose attached, does the suction seem ok at the opening where the hose goes into? If so, then you have a clog in the hose or down below where the dirt is first sucked up. If suction is poor at the vacuum, then check the filters, they go bad after awhile.
Feb 24, 2008 | Sanyo Bag-Free SC-240 Canister Vacuum
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
220 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
