Reddmango 2GB MP3 Player Mr118 won't play, red light flashes on and off quickly, not seemingly stuck on 'lock'.
  • Anonymous Apr 30, 2009
    When I turn it on the light comes on, but it just turns itself back off again. would appreciate any help on this one
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: RCA Opal MP3 player stuck on "keys locked"
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Posted on Oct 07, 2008
SOURCE: mp3 reddmango mr118 write protected
On the side of your mp3 player is a silver button with a lock on it one showing it open and one closed, slide it across towards the open position then it won't be write protected.
Posted on Jan 15, 2009
  • 2418 Answers
SOURCE: Can't delete files from mp3
Hook it up to your computer, right click on my computer, click on explore, find your player, click on the file you want to delete, right click that and choose properties, see what the attributes are set too. Change or un-check any that are checked. close all windows go back in to my computer and see if you can delete tham know.
Posted on Jul 18, 2009
zherbert
  • 6 Answers
SOURCE: I have a Reddmango MR118
You should be able to open the folder up in explorer and view all the songs in it, like a flash drive. Just click on the song you dont want and click the delete key! This has to be done on the computer.
Posted on Mar 05, 2011
RadarRon
  • 398 Answers
SOURCE: REDDMANGO MR118
MP3 is audioMP4 is videoYou can NOT use MP4 format, it's that simple.
Posted on Oct 06, 2011
Why won't my new mp3 work properly?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 20, 2012 | Audio Players & Recorders
I have a reddmango mp3 player. it stopped working for abit but i format it, then it started working again because the red light was flashing but when i put in my headphones in i cant hear nothing...
If you formatted it, you will have to but music back on to it.
I assume that you tried the volume controls, so you should verify that the ear buds are working properly. Either try your ear buds in another device or try a different set of buds (that you have verified work) in your MP3 player.
Sep 22, 2011 | Audio Players & Recorders
I have a Reddmango MR118 MP3 player, it wont let me delete music files from it. How do i delete the songs i don't want on it?
Mar 05, 2011 | Audio Players & Recorders
Vista media player will not recognize reddmango mr118 mp3 player when i plug it in.i have just bought the mp3 player
It will be recognised as a mass storage device, maybe drive E or F in 'my computer' so just point the media player to the location of the mp3 files, or open the folder with the files in and drop them onto media player.
Jan 27, 2011 | Computers & Internet
Coby 2gb red light flashing
I know exactly what u mean. same thing happened to me.
Go into the coby media manager.
Click on music
when you list of songs appears, right click on a song
then click on syncronise.
do that for each song. this syncronises your songs to your player.
it worked for me!!!!
earlene
May 05, 2010 | Coby MP-200 MP3 Player
Jul 18, 2009 | Audio Players & Recorders
Cant take reddmango mp3 player off shuffle
If it's on shuffle, hold down the - key and then press +. It will put it back on to sequential. (Just tried it and it works!)
Mar 19, 2009 | Audio Players & Recorders
Mp3 reddmango mr118 write protected
Jan 09, 2009 | Audio Players & Recorders
97 people viewed this question
 Grubhead
Grubhead
