Question about HP Office Equipment & Supplies
Laserjet 4L printer has a streak on the left side of paper with ink blotches in the streak
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Look at the toner cartridge it is be coming from there,replace. check to see if there is something stuck on hte drum causing the blotches, clean w/alcohol or replace
Posted on Sep 17, 2008
Streaks paper laserjet
Due to faulty cartridge streaks appearing on paper/ITB. Take 4 cartridges out,check each cartridge drum surface for streaks,replace the faulty cartridge/s..
Sep 17, 2013 | HP LaserJet 4650 Color Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
New toner, still get lines on paper when printing
Is there toner streaks on the drum?
Remove toner cartridge and push back the drum cover (on bottom)to check. Could be just another bad cartridge.
If the drum is clean, then it's coming from the fuser. You can have it replaced /rebuilt, but I personally wouldn't spend any money on this one.
Mar 29, 2009 | HP LaserJet 4L Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Laserjet 4L
What you actually hav is a cracked gear on the main motor. It shows up when you install the cartridge because it requires more torque to drive the cartridge. Remove the top cover, the side formater board. There is 1 screw on the side and 2 on the top that hold in the motor. The motor with the gear attached is available from Dale at Seattle Platen, 1-800-221-2388. Gear only isn't available. Cost is around $25.00.
Jun 22, 2008 | HP LaserJet 4L Printer
Left & right streaks when printing
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
May 09, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
Paper LED blinking
Try feeding using bypass, probally worn/dirty/broke paper cassette paper feed roller having trouble feeding the paper in.
Sep 30, 2007 | HP LaserJet 4L Printer
150 people viewed this question
Ben Johnson
