Assuming your turntable is wokring and your cups / dishes are microwave safe, then I would suspect the magnetron is failing.
That's a 2006 model, so the magnetron would definitely be under warranty.
But if it's more than 1 year old, you would have to pay for labor to get it replaced (if it's bad) and that would almost certainly not be economical.
For warranty issues or to find a local servicer, you can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
Hello
Thank you for your response .
I have a Sharp Carousel mod. # R-408JW-F
Thank you
Tim
First, be sure your dishes & cups are truly microwave-safe.
From the FDA: "Only use cookware that is specially manufactured for use
in the microwave oven. Glass, ceramic containers, and all
plastics should be labeled for microwave oven use."
If they are, then your magnetron may be failing. Overheating is one sign of that.
How old is it? Please reply back with your brand and model number so we can help you.
