Question about Toshiba 65H80 65" Rear Projection Television
Toshiba 65H80 Rear Projection Multi Image Problem ( Trailing )
Have had a multi image problem since new. Service techs can't find a reason. Not a weak signal problem. Hooked to two differant cable network companies since new.
When turned on, I get multi images only when image moves quickly on the screen. If I turn off the TV and back on again quickly, the multi imaging stops. Now it has gotten worse, I have to turn it off and on three or four times before it stops.
Any ideas? Thanks
    Scholar:
  • 188 Answers
There is a problem in the imaging circuitry in your Toshiba. It could be anything but most likely in the focusing circuitry. I would have a certified Toshiba repair on it.
Posted on Sep 17, 2008
My tv toshiba 51'' rear projection wont come on, no sound or image but i hear a click when turn on and off.
most common reason is convergence problem--unsolder both chips and see if set will power up with them out of the circuit.
May 02, 2012 | Toshiba 51H94 51" Rear Projection HDTV
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
Toshiba 55" TheaterWide TV powers on, then loses image
Normal repairs are 200-400 dollars service calls are75-150 depending on area and should go towards estimate but not refundable. It sounds like a problem that a tech should see first.
Apr 12, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Samsung projection tv model pch521r
What type of cables or connection are you using?
Jun 04, 2008 | Samsung Televison & Video
60pp9352 convergence ic replaced multi points corrected but image squeezed
one of the resistors must be open, you cant always tell by looking if theyre open you have to remove one leg out of circuit then test them for resistance they can only be 5% out of tolerance, any more than that and they must be replaced.
Mar 27, 2008 | Philips 60PP9352 60" Rear Projection...
No image on my TV
Bad hyper module = no longer available = have qualified tech
rebuild yours = replace bad caps on board...............T.
Dec 08, 2007 | Toshiba 42H81 42" Rear Projection...
65h80
Yes look for www.bluestar-online.com and check your set and make sure it's the stk392-110. If you can solder you can carefully change it. I would replace all, you may have 2 or 3 in there. Also make sure you don't bridge the pins. Meaning soldering 2 pins together, just be careful. Unplug set and be careful of unscrewing board.
Aug 15, 2007 | Toshiba 65H80 65" Rear Projection...
Toshiba 65H80 65" Rear Projection Television Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
