Question about Ricoh Computers & Internet
Ricoh 7100 Hello, I have a Ricoh 7100 that tells me to add cyan toner, we did that and now it says something about fuser oil. Any Ideas? Cost effective to repair machine? Paula
  • 446 Answers
Fuser oil is a necessity in ricoh machine, it is entirely different consumable than toner (cyan) you dont need to repair the unit only to add oil or fuser oil, pls contact your supplier to buy one and install asap
no need to send to repairshop
Posted on Sep 17, 2008
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Ricoh 7100cl
I belive this is the cartridge type oil unit. If you look at the top of the oil cart you will see 3 metal contacts.....clean these and look for where they make contact in the machine clean those and gentley pull down on them so that they make a little better contact this should clear your message provided there is oil in the carttridge
Sep 24, 2009 | Gestetner C7435n Laser Printer
Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
May 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Ricoh Aficio CL2000N Laser Printer
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
Add Toner
Your machine has got a toner pump on each of the colours wich transport the toner through pipes , these pipes get blocked and needs to be vacuumed out to clear the blockage .i got the service manuals if you need any further assistance
Nov 13, 2007 | Ricoh Aficio AP3800C Laser Printer
Computers & Internet Logo
148 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
