Question about Dell Inspiron 6400 Notebook
No display. I am an electrical engineer with a lot of experience fixing older desktop systems but new to spelunking into laptop issues. That said... My system was fine night before. Powered on. LEDs seem to indicate system is running. LCD panel is blank, no POST/Dell logo or anything. At some point the display again worked for about 5 minutes and then went blank again and has not returned. LCD backlight is on. Ran Spinrite on the HDD. It is fine. I have an Invidia Go7300 card. The VGA connector looks like it is on the motherboard. Is there a way to default to the on-board VGA to see if I am having problem with the graphics adapter. Any other suggestions?
  • 2 more comments
  • ErikBleuer Sep 17, 2008
    Hi Cactus,
    Before going inside the laptop I had no way of turning the system on with the lid closed. With everything open I can actuate the lid pin switch manually. Indeed my external VGA monitor woke up and now displays a bunch of $$ $$ $$ $$... while the CD-ROM with my Windows install disc inserted trys doing something. I don't get the usual BIOS POST screen with the option to enter setup. Eventually the CD-ROM drive stops, system beeps and states on the VGA.....
    "No$footable devmcew--strike F1 to vetr}$boot, F6 fov setup utility, F5"...
    F6 retries to access the CD-ROM minutes later repeats the above. Next time around I pressed F5 and got to Pre-boot System Analysis. It is now running system tests (still never had ability to go to CMOS setup) but this is progress. Now, my finger slipped of the lid pin switch and low and behold the LCD came up displaying what was on the VGA! I don't thing my problem is solved yet, but your suggestion with the lid switch got me moving in a positive direction again. Many, many thanks!!!
    I'll post again when the tests complete.
    Also, FYI I do not have the HDD installed presently.
    All tests passed. rebooted and tried it again. I noticed a difference on the display before there were vertically lined up dots throughout the display on both the VGA and the LCD. The second time the display was clear of dots. Again all tests passed. I fear that my problem might be the mother board and not the video card problem since I saw those dots on both. In addition, I am afraid that my issue may be intermittent.
    I have to go to work now so I'll have to do more tomorrow to put my system back together. At this point all I have done is reseat all the connections inside the case that I could.
  • The Cactus May 11, 2010
    Hello ErikBleuer,
    By your question and info above, you sound like your qualifications are well beyond me, but maybe I can help anyway!
    I just want to know what happens when you connect an external monitor to the laptop, if anything comes up. Most machines I've ever worked with will default to the external monitor from the outset, sometimes when you power on the laptop and leave the lid closed. I had an 8200 that would work in this manner.
    ~Cactus
It might be a problem with the lcd cable . open the comp in front of you at an angle of 90 degrees . just above the keyboard there is a pannel on which the power button is also there . we need to take out that pannel , on the far right hand side of that pannel there is a place where you can fit a screw driver . place a screw driver there and then pry the pannel from right hand sidew towards the left hand side . now you will be able to see two screwws which are securing the keyboard open them and you will be able to tajke off the keyboard . now look for the lcd cable which is comming from the lcd through hinch and going in the motherboard , we need to unplug that cable and then plug that back and while doing so blow some air in that connector . the cable might be connected to the motherboard with a connector below the keyboard or below the pannel which we took off earlier .
Posted on Sep 19, 2008
Bumped my Acer Aspire 5601AWLMi rather hard. Everything froze and after hard booting it will not come on.
Sounds like this is most likely a hard drive issue... You may have scratched your disks with the bump. When you boot up your computer, you should hear a beep - this is your POST (bios startup). If you hear this beep, but the computer does not boot any further, it is almost certainly a Hard drive issue. Some computers don't always play an audible 'beep' but if your computer shows the initial boot screen then goes black, or freezes up during the OS load, you can expect that you will need a new drive. If this is the case and you have experience in a fresh installation of an Operating System as well as experience in installing a hard disk drive into a laptop, then you can buy a new hard drive and DIY. If you do not have experience in these areas, I strongly suggest taking your computer to an expert to have it fixed.
If you don't hear the beep or the initial boot screen never displays, you may have a major issue with the motherboard itself. Either you have dislodged a necessary connection between components or you have broken a circuit. In this case, unless you are a seasoned hardware professional, I suggest bringing your computer to an expert to have it looked at.
Sep 13, 2011 | Acer Aspire 5601WLMi Notebook
Tip
Areo will not start on a clean installation of Windows 7
I just resolved this issue on a new system. The user had been running the system about 5 days and the Aero would always drop out to Windows Basic mode as soon as the system booted to the desktop.
The cause turned out to be the Windows Experience Index had not been run.
Windows 7 requires a minimum Windows Experience Index before the Aero Experience to function.
If Aero will still not run after the Windows Experience Index has been run, tun the Aero troubleshooter and reboot after the troubleshooter finishes to resolve the problem.
on Mar 19, 2010 | Computers & Internet
How can i recovery my system?
Sometimes your computer may experience problems and performance issues, which could interfere with common tasks. However, there is no need to worry because this can all be remedied by restoring your computer to an older date. Restoring your computer will allow it to go back to a previous setting before the date that you experienced the problems at. It is possible to restore your computer from points that are a day old to points that are even a few months old.
1.Click "Start" from your desktop. Open your "Control Panel." Click on "System." This will be near the bottom of the control panel and deals with the security, protection and performance of your computer.
2.Click "System Protection" under the Task menu. The task menu is on the upper left-hand corner of the window.
3.Click "System Restore" on the new window. Choose the recommended restore date, or choose a different date. "Click choose a different restore point." Click "Next" to change the restore point. Choose one of the last five dates shown, or click "Show points older than 5 days."
4.Click "Finish." Your computer will now automatically restart and apply the changes.
I hope you find it very helpful. Thanks.
Sep 05, 2011 | Computers & Internet
Usb ,web cam audio they dont work i download driver i tried a lot of time also through its recovery disk it doesnt work its hard ware problem wat can i do
Hi semiro20,
If you have downloaded the drivers via http://support.toshiba.com and already did full system recovery but still having issues, you are right, this is a hardware problem and you need to have the computer serviced. If you purchased your Toshiba unit in the US, call 1-800-457-7777. If you purchased it in Canada, you need to call 1-800-663-0378.
Cheers.
Sep 01, 2011 | Toshiba Satellite L505-S5966 Notebook
Displays work fine until After Windows splash screen appears...then unit goes dark on both LCD and External display... Tried fn F5 combination with no success.. Any suggestions??
I suspect a display driver problem - try safe mode. After powering on, start tapping on the F8 key about once a second. You should end up with a bunch of white text on a black background. Options will include "Safe Mode" and "Last Known Good Configuration......". You could try the latter as sometimes that's enough to get you to a desktop. If not then power off/power on and try safe mode. If this gets you to a desktop then it is likely a driver issue and further work will be needed to to get you fixed up. Please post back with your experiences.
Feb 28, 2010 | Acer Aspire One Netbook 8.9" Notebook
ATI x600 displaying checkerboard pattern when playing games
Sounds like specific overheating problems that only affect certain game engines or certain functions in them or is may be memory leak that only happens when computer has been running programs for a period of time.
No One Lives Forever uses Lithtech 2.0: Talon engine, however it was later revised to Lithtech 2.2 whose fixes were included in the latest NOLF patch. Make sure you have the latest patch for NOLF.
Freedom Force uses NetImmerse engine.
If possible try if you have same issues with another games with old NetImmerse engine. See list here: http://en.wikipedia.org/wiki/Gamebryo#NetImmerse_games
Far Cry uses CryENGINE. Far Cry was actually developed by Crytek as a technology demo for Nvidia display adapters and when the company saw its potential, it was turned into a game. As a conclusion I would say this game is very likely optimized for Nvidia display adapters and issues may be because of ATI display adapter drivers.
If nothing else helps try somewhere with nVidia. ATI has a lot of issues with old games released before or near year 2000, because of its drivers and they do not seem to correct driver issues on old games. When looking nVidia driver release notes you find more often game specific corrections or maybe they just document them better.
Dec 28, 2009 | ATI RADEON X600 SE 128MB DDR1 PCI Express...
Multiple Displays on HP dv2601TX
In my dealings with HP and their supposed high end laptops....I'm astonished you got 15-16 months out of it. I refurbish them and go to extremem lengths to make sure that they don't come back with ptoblems and knock on wood I have yet to have a return because of a part or system failure. Sell your laptop on E-Bay and at least get some of your money back from the experience. I usually end up buying the laptops with problems and tearing them down and rebuilding. My focus is eliminating the over-heating issue. There are some changes out there, HP is releasing new BIOS updates for its laptops...these new BIOS instructions contain new algorythims to make the fan more efficient and run faster and longer to help cool the unit. Copeer sheeting is also used on the processor and graphics to augment cooling. Good luck, ParrotHead PC Repair
Sep 06, 2009 | HP Compaq nx7010 Notebook
WHAT DUZ "OUT OF RANGE MEAN"
The laptop is widescreen at a guess. The external monitor is not. You need to change your laptop screen resolution to be something like 1280x1024, or, you need to tell the monitor to be a display EXTENSION not a mirror. Right click the desktop, properties, then Settings. Click on the 2nd screen, and set its resolution to 1024x768 or 1280x1024. It's here you would tell it to extend not mirror too.
Jul 12, 2009 | Star Logic 17" LCD Monitor
How to fix short circuit on Samsung X20 laptop?
sounds a lot like the power controller chip is shot. you will need a schematic and correct replacement parts..www.samsung.com might have a service manual for that.
Oct 09, 2008 | Samsung X15 Notebook
Dell Inspiron 6400 Notebook Logo
109 people viewed this question
Alun Cox
