Question about Fujitsu fi-5120C
Keep scandall in background
Using Scandall 4.3.11 -- works great but scanning is always "on top" of other windows -- if I try to work on something else, the next page scan goes on top again. the result is that all computer work stops while scanning.
I cannot find any preference settings to change that. maybe there aren't any ?
    Problem Solver:
  • 12 Answers
Possibly you need a more professional program. Scanning utilities following scanners (free) aren't a "Production" tool. Using PixEdit you can scan with one single click and after the scan is finished you could scan the next stack of pages. While it is then scanning the previosus document is processed with blank page removal, deskew, OCR, barcode recognition and a lot of other stuff. The reason is PixEdit using the mulitple cores in modern PCs.
Posted on Aug 20, 2009
Saving appended files in Scandall 21 version 4.3.17
when you are saving the file make sure you are saving the file in the desired format ... the save as type option.
Jul 14, 2008 | Computers & Internet
Scandall pro
Unchecking the box in RoboForm worked for me! Thanks!
Jul 06, 2013 | Office Equipment & Supplies
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Jul 20, 2009 | Fujitsu fi-5530C Scanner
Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
Jul 18, 2008 | Epson Perfection 1250 Flatbed Scanner
Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
May 23, 2008 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
286 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
