Question about Canon PIXMA iP90 Mobile Printer
Canon i90 I have an I90 when I connect it to my computer and turn it on the green light blinks amber. The print box says the printer is offline. How do I print a test page with the buttons on printer?
If error light blinks 4 times
will be a hardware error.
Canon mention to be a cart. out of position.... but there are wrong.
On the service station(right side) you will se a metal plate
wich is holding service station. I did find it out of position
and just push it till it cliks on the tabs.
After that repower yor unit and shuld be fine.
just to mention that you don't need to take it apart...you can accese it thru front opening lid.
Good luck
sorin
Posted on Jan 27, 2009
Black printing is incomplete. faint, blurry, ghosts, erratic
More than likely your printhead is failing. This is a common problem with the i70/i80, i90/iP90v and i100. The printhead is easy to replace. Open the cover, let the carriage center, powerlift printhead frame lever and lift out printhead. You can test and/or clean the jets in the maintenance tab in the print driver.
Jun 16, 2010 | Canon iP100 Portable Printer
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Canon i90 gives error 5100
This means that the Movement of the Print Head Holder is blocked. To remedy this carefully check the printer and clear the paper jam or foreign object that is preventing the Print Head Holder from moving. With the power off the Head Holder should be able to be moved gently by hand. Cancel printing from your computer, then turn off the machine, and turn it back on again
Oct 02, 2009 | Canon PIXMA iP90 Mobile Printer
My canon i90 printer wont print. it appears to working perfect but the result is a blank paper. i have installed new cartiages & run all maintenance functions.
It sounds like the printhead is plugged, but there is also a firmware upgrade that helps position the printhead for better cleaning, Canon suggests you try deep cleaning 3 times in printer maint. from the properties menu before replacing the printhead. I use a syringe to put a couple drops of water on the cleaning pads on the right to help with cleaning.
Aug 31, 2009 | Canon PIXMA iP90 Mobile Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon i860 "printer offline" but light is blinking
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
Oct 17, 2006 | Canon i860 InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
225 people viewed this question
old marine
old marine
