Question about Brother SX-4000 Typewriter
Correction spool how to install the correction spool on a brother SX-4000 typewriter. Have tried following instructions to no avail. thanks.
  • 3 Answers
The feeder spool goes on the pin to the left of the carrier with the sticky side toward where the paper would be. Feed it through the ribbon guide and then attach the other spool on the pin on the right. Be sure both spools are snugly snapped into place - mine kept flying off.
Posted on Oct 01, 2008
HOW DO I FEED the correction tape replacement on my brother sx400
Generally speaking the full spool goeson the L side qand goes across theprint area with the dull side toward the paper. It is easier if you remove the print wheel
.DickyO
Jul 20, 2012 | Brother SX-4000 Typewriter
How do i install the print wheel?
Go to brother.com, click on support, poke around there you will find a manual for most T/Ws.
DickyO
Mar 16, 2011 | Brother SX-4000 Typewriter
How to install correction tape on a brother sx 4000
Go to Brotherinternational.com, click on support you will a manual there.
DickyO
Feb 11, 2010 | Brother SX-4000 Typewriter
Typing wrong letters on Brother SX-4000
Try hitting [CODE] + [RESET] at the same time to reset the cartridge. Make sure the cassette is installed correctly.. the "ear" on the cassette should always be on the upper right.
Mar 24, 2009 | Brother SX-4000 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000
1) Use the [SPACE BAR] or [BACKSPACE] to move the carrier to the center of the platen.
2) Open the top cover
3) Remove the cassette ribbon, if installed
4)Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, and lift it up and out.
5)Pass the new tape through the left guide, behind the ribbon guide, and out through the right guide. The rough (sticky) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it.
9) Replace the cassette ribbon and close the top cover.
10) Press [CODE] + [RESET] to move the carrier to the previous position.
Mar 19, 2009 | Brother SX-4000 Typewriter
Accessing memory on the Brother typewriter model # SX-4000
this machine has no memory storage, therefore, nothing to access
Sep 16, 2008 | Brother SX-4000 Typewriter
Brother sx-400 eraser not working
It can only use the brother dry lift-off # 3015, I think, shining side faces you.
Mar 01, 2007 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
