Question about HP LaserJet 3055 All-In-One Printer
Not able to pick up the paper
Hi this is rakesh from surat
iam using the prionter of hp model 3055
last 1 month i am facing a problem with the error "NO PAPER PICK UP"
I had send the mail to my comany for technical support also but no solution came.
kindly provide me the hp engineer for this
my address is b-7 divya darshan appt
opp rishabh tower adajan patiya rander road
surat contact no 9925555845 & 0261-6542539
as it is in under warranty so do the needfulasap.
Iam using the prionter of hp model 3055
last 1 day i am facing a problem with the error "NO PAPER PICK UP"
Posted on Sep 20, 2008
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
I have a Hp Pavilion dv6000 and iam having problem with the dvd writer, while burning files with nero 7 its stopping and giving an error message . Please help me resolve the issue
hi friend, you should buy a DVD lance cleaner DVD. which is avilable in your electronic market. use it.bcoz, your dvd lance have dust on it.
if, it again give you same error then, goto your nearest service center.
Regards: Rakesh
Jan 26, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
I have a " no paper pick up" error message that I
3050 or 3055?
I checked the User Guide for these models; In the error section:
No paper pickup error. The all-in-one has failed to pick up a piece of media.
1. Verify that the media was inserted far enough into the input tray.
2. Reload the media in the input tray and press to continue the job.
3. If the error persists, contact HP Customer Care. See HP Customer Care or the support flyer that came in the all-in-one box.
Under print problems there is some additional information.
The all-in-one does not pull media from the media input tray.
1. The all-in-one might be in manual feed mode.
?? If Manual feed appears on the al lin-one control-panel display, press to print the job.
?? Verify that the all-in-one is not in manual feed mode and print your job again.
2. The pickup roller might be dirty or damaged.
Contact HP Customer Care. See HP Customer Care or the support flyer that came in the all-in-one box.
The setting of 'manual mode' sees the most likely problem of the above. If the setting was not in manual mode, before investigating further you may wish to try a simple reset. Sometimes, restarting the product can clear a paper feed issue. Follow these steps to perform a reset.
Reset the printer
1. Press the Power button ( ) to turn on the product.
2. With the product turned on , disconnect the power cord from the rear of the product.
3. Unplug the power cord from the wall outlet.
4. Wait at least 15 seconds.
6. Plug the power cord back into the wall outlet.
7. Reconnect the power cord to the rear of the product.
8. If the product does not turn on by itself, press the Power button ( ) to turn it on.
If you also see the "Document feeder mispick" Error Message on the Control Panel you might want to refer here: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1140783&prodTypeId=18972&prodSeriesId=1140783&objectID=c01487637
You may also wish to visit this page to have HP auto-check if your driver is current. See right side of page:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=115&prodTypeId=18972&prodSeriesId=1140783
Dec 14, 2010 | HP LaserJet 3050 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Document loaded showing 3055
Sensor flag would have got stuck, check adf paper presence sensor
Oct 09, 2017 | HP LaserJet 3055 All-In-One Printer
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Jan 09, 2008 | HP DesignJet 450c InkJet Printer
HP LaserJet 3055 All-In-One Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
