Question about Packard Bell Computers & Internet
Hard drive says its disabled - Packard Bell Computers & Internet
  • 61 Answers
Try to reset the IDE or SATA cable and try and load to default setting in your bios
Posted on Sep 17, 2008
Disable ahci
That is not practical but you can set the bios to load from the hard drive last or just remove the hard drive.
Dec 03, 2013 | Computers & Internet
Remove Write Protection
You must disable the hard drive first to remove the write protection. So, right click on the external drive to disable it, connect the hard drive. Go to My Computer and find the hard drive, right click on the hard drive and de-select/remove the tick on the check box and change it to read only, then exit.
Nov 14, 2013 | Computers & Internet
I want to install windows xp-2 in my laptop presario cq42 notebook, i have a proble with hard drive for sata disable. in this laptop the bios not show the sata disable feature. so i want to disable this...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Compaq Presario Notebook
Disable SATA in BIOS, well but there is no option in Bios to disable or enable SATA. Lately HP DV2000 comes with bios without this option (DV2000 - DV2680ee, I lost a lot of money and time with this...
You should not need to disable SATA as it is a way to interface with the hard drive. In the BIOS you can disable a hard drive to boot within the boot options.
May 06, 2011 | Computers & Internet
My Hornettek 1TB external hard drive has a fan that has recently started making a loud buzzing noise. Is the fan replaceable? Also is there a way to disable the fan without causing heating issues for the...
disabling the fan will cause heat issues , a replacement fan
fron the manufacturer or a universal from tiger direct
will work.
be sure no dust or debris is causing the noise first.
Oct 04, 2010 | Computers & Internet
When i going to write any thing in pen drive it shows write protected For that i need a solution
Any user use USB anti virus program?
If yes try to this,
uncheck "Disable writing of any usb devices".
Dont use this software? any one (maybe your friends use this software and disable write protection in your pendrive ) contact your friends.
OR
download USB anti virus program from google search, and try to uncheck disable writing option.
Mar 18, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Chkdsk runs sporadically and never stops
Sometimes it happens that disk check always starts to check the file system on one or more drives for consistency. If any key is pressed, the disk checking is aborted. Actually this is because some data structure of the drive or some file is corrupted which can not be recovered and check disk is always run at Windows startup. Or sometimes it may take several hours for disk checking to scan all the drives. So disabling it or postponing disk check is better. There are several methods to disable disk checking at Windows startup. Two of them are given below:
Method 1: Using CHKNTFS utility CHKNTFS is a utility that has been developed by Microsoft to disable disk checking on certain drives at Windows startup. To use this utility go to Start –> Run –> cmd.
If you want to disable check disk on C: drive, use the following command on command prompt.
chkntfs /X C:
If you want to disable check disk on two or more drives, just keep on adding the drives:
chkntfs /X C: D: E:
This will disable check disk on C, D and E drives.
If you want to restore what you have done, that is, enable automatic disk checking on all the drives again, just run the following command:
chkntfs /D
This will restore all the drives to automatic disk checkup.
Method 2: Using Registry To disable automatic disk checking at Windows startup through registry, go to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
In the right hand pane, double click BootExecute.
The default value of the key is autocheck autochk *
* means every drive is checked for consistency. Just add /K:C at the end before *. /K switch will disable autocheck on C: drive at Windows startup. So the final value should look like this:
autocheck autochk /k:C *
If you want to add more drives, the key should look like this: (disabling C and D drives)
autocheck autochk /k:C /k:D *
If you want to restore everything to default, just replace the key with the default one i.e.,
autocheck autochk *
Hope this will solve this issue.
Please rate your coments.. This will be helpfull to others.
Thanks & Regards
Nanda Kishore
Mar 31, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a dell c600 and my hardrive isnt recognised
go to the bios while restarting your laptop and there is option to disable sata for hard drive disable sata you hard drive will probably start working
Dec 05, 2008 | Dell Latitude C600 Notebook
Computers & Internet Logo
52 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
