Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
Infocus LP540 --- display
My infocus lp540 is ceiling mounted. When the display comes on - it is cutting off the right hand side of the image ---it is not a matter of adjusting the projector left, right or up and down.
    Scholar:
  • 167 Answers
It sounds like you may be feeding it with an HDMI source using an HDMI to M1-D adapter...
If this is the case, make sure the source in not set to a resolution higher than 720p.
However I really need more information to offer a definitive solution.
Take Care!
Posted on Dec 29, 2009
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 Projector Lamp Does Not come on> it has an error message; "Lamp didn't Strike". Does that mean the Lamp/Bulb is bad?
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Jan 13, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
Help me how to open the lp540 power supply show me diagram
Best would be to download the users manual which should be having clear directions for your pupose. A link from where you can download this manual is: http://homeappliance.manualsonline.com/search.html?q=InFocus+LP540+Multimedia+Projector&submit.x=35&submit.y=8. Hope that helps.............sodeep
Jul 26, 2009 | InFocus Office Equipment & Supplies
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540
I haven't serviced an infocus projector before, But I have seen 3 or 4 Red cutting out display simptoms on projectors caused by bent or pushed in gold pins on the VGA leads. (it always seems to be red!) I won't comment on insides but do check this basic tip before delving in too deep. Good Luck
Sep 24, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Projector InFocus LP540
ask the guys at GOTABULB.com Through e-bay they are very good in america
Aug 29, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP 540
1. Have you recently changed a lamp and if so, Did you reset the lamp timer and is your filter (if it has one) clean?
2. can you hear a FAN start when you turn the unit on?
Jan 15, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
140 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
