Question about Xerox WorkCentre XD130DF Laser Printer
J2 Error on XD125F
I have replace the Toner & the drum with new ones, but when the red light came on I thought was the toner and I replaced with new one the red ligth still on but I could make copies now appear J2 I replace the drum but now don't let me make copies.
What is the problem?..
martin
tremmar@sbcglobal.net
  • tremmar Sep 18, 2008
    thank you for the help I really appreciate it the effort you did in to help me out of this problem.
    but I want to add that once you put the gear with the flag up to the right you need also align the gears in side the green part there is a notch that you need to bring it all the way down those will align just right with the others gears and the green part will go back in with no problem.
    Martin
    President:
  • 2,072 Answers
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Posted on Sep 17, 2008
  • Rick Kasper Sep 18, 2008
    Yep. I did not write it out extensivly. Thank you for the remindder. And Glad it worked.
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
There are 3 lights on the xerox 1020 first one
you replaced the drum too soon, replace old drum until red light flashes then install new drum.
Jan 22, 2010 | Xerox Office Equipment & Supplies
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
J2 ERROR
Replace the Drum Cartridge.
Jun 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
Xerox copier
J messages on Xerox machines always refer to toner or drum.Is the toner out , you could give it a shake (might be a good idea to go outside!) Sometimes it will run out without displaying a message(Pyramid of dots for out of toner) Drum end of life usually comes up with a crossed circle or similar .If all OK you could have a blocked toner supply auger or lumps caused by storing toner in sunlight, both would require the toner system being vacuumed out.
Nov 26, 2007 | Kyocera RI-3530 Black and White Copier
Xerox WorkCentre XD130DF Laser Printer Logo
114 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
