Question about Philips 30PW850H 30" TV
HD feed problem
I have the Philips 30PW850H HDTV - it's a HD monitor. I have it connected to a Motorola HD set-top box using a video component cable (RGB standard, high quality). There are 2 sets of jacks on the back of the TV that are for RGB - one for AV1 and one for AV4. When I plug the cable into either set and then tune AV1 or AV4 on my TV, I get a black screen and my TV makes a strange buzzing noise that repeats over and over at different pitches. It's almost like it's trying to tune it in and can't process the signal.
I've had this TV working with a Comcast HD cable feed before, but I moved recently and now have Verizon. Could it be that something is broken in the TV? I've already tried different cables and Verizon says the box is fine. Any ideas?
Thanks in advance.
This tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Posted on Jan 06, 2009
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
I' attempting to connect my hd cable box to my hd projection tv. i'm confused on where to connect component cable to tv. i haven't a clue what i'm doing or where to begin. i have the cable connected to the...
Please post the Brand/Model of you cable box and that of your TV so I can provide you with an answer that is more accurate than a guess.
The guess is, since we are talking about HD I will assume that your cable box has an HDMI connector and you have also an HDTV with HDMI connector somewhere in the back. In that case you will need an HDMI cable and that will connect both Audio and Video signal. Then you just set your input source selector on your HDTV to HDMI (if multiple select the number of the one where you connected the cable box), and you should be getting picture and sound.
Now, if your HDTV has no HDMI input then it will be very likely that you will have to use a Component cable that is ONLY for the "video" signal and looks like 3 RCA connectors color coded as Red, Blue, and Green. You will need to get and additional cable to feed the "audio" signal from the cable box to the HDTV using a stereo cable with RCA connectors which are usually color coded as RED and WHITE.
Note: This setup although better than nothing, is somewhat defying the purpose of having HD. The signal in Component connections are analog (although of better quality than Composite i.e. the old single video cable color coded as Yellow). The analog signal is limited by design and will get you only so far in your HD experience. The HD signal is digital and will yield the highest quality in both audio and video.
Assuming you are paying extra for channels that are HD then it would be worth it to do some more research or ask for help to one of your savviest friends so you can get the best gear and results with the least expense ;)
In all cases you should be able to see the programs and hear in stereo, your experience will vary as: - Your video signal may be a 480p instead of getting a higher 720p or 1080i. - your audio signal although some movies are available in 5.1 surround, not having a surround system will just give you the stereo sound from the TV.
Either way is your call how you want to experience your media... if you like to read more on the subject a quick start could be the TV glossary at crutchfield for instance:
Jul 23, 2010 | Philips 60PP9202 60" Rear Projection...
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Philips 30PW850H 30" TV Logo
191 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
