the service guy from Sony India is demanding INRs.11,000/- replacing the main board. is it not possible to locate and rectify the fault in the main board instead ???the service guy from Sony India is demanding INRs.11,000/- replacing the main board. is it not possible to locate and rectify the fault in the main board instead ???
You can't post conmments that contain an email address.
most mainboards are not serviceable outside if a fuse or bad cap. If can be very difficult to even get schematics for them, just replace itmost mainboards are not serviceable outside if a fuse or bad cap. If can be very difficult to even get schematics for them, just replace it
T'Con board fault. check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
8 blinks in KLV-32S400A shows Audio Error Check audio voltage supply from power supply board, if OK, replace GP Board (main board) and if audio volts are not available, check/ replace power supply board.
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
