Question about Nikon Coolpix 775 Digital Camera
775 Digitaal Camera
IT WORKED FINE. I DID NOT USE THE CAMERA FOR ABOUT ONE MONTH. THE BATTERY WAS CHARGED. THE DIAL WAS ON AUTO. I PRESSED THE BUTTON AND IT TOOK LITTLE PICTURES LIKE THE MOTION PICTURE PHASE AND IT WOULD RUN UNTIL THE CARD WAS EMPTY. I TURNED THE CAMERA OFF TO STOP THE PHOTOS. I PUT A NEW MEMORY CARD IN AND THE SCREEN TELLS ME NO MEMORY CARD. I PUT ANOTHER CARD IN AND THE SAME NO MEMORY CARD. NO FLASH, AND THE BUTTON PRESSES BUT NO ACTION. HELP, HENRY
    Scholar:
  • 80 Answers
Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Posted on Oct 25, 2008
I have a Nikon d3300 that turns off automatically after i take a photo - can you assist
If the screen display is shutting off, that's a normal function. If the camera is entirely shutting off it might be a bad battery or a very weak battery.
Sep 28, 2016 | Nikon Cameras
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
Cannon powershot SD750 digital EL continuous shooting not working
I had the same problem until I realized that you can't have the dial selected on Auto. Move it to M for manual and it will shoot continuously.
Jun 17, 2009 | Canon PowerShot A550 Digital Camera
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
NO Power
Possible causes Solutions
/ Corrective Actions
The power does not
turn on.
The ViviCam 6300
suddenly powers down.
The image is not
captured when the
shutter button is
pressed.
The flash does not fire.
Continuous shooting
is not possible.
Cannot transfer files
over a USB connection.
* Load new or fully charged battery.
* Load the battery in the correct direction.
* Close the battery cover correctly.
* Properly connect the AC power
adapter.
* Set the option of Auto Shut Down to Off.
* Turn the power back on or charge the
battery.
* Rotate the mode dial to A , P , SCENE
, Tv , Av or M.
Transfer the desired files to your
computer and then delete unnecessary
files, or use a different memory card.
* Select a different flash mode.
* Select [Single] in the capture mode .
* Insert a new SD memory card.
* Check all connections.
* Install the USB driver on your computer.
* Turn on the ViviCam 6300.
* The battery has run out.
* The battery is not oriented correctly.
* The battery cover is not closed properly.
* The AC power adapter (optional)
is disconnected.
* The function of Auto Shut Down in
Jan 25, 2008 | Vivitar ViviCam 5386 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Command dial is operating mechancally but does not adjust/ change any settings.
If it is still under warranty- your are in luck A repair shop if you can one- will charge about the value of the camera. Bearing this in mind and if you have the nous and suitable fine tools- have a go at looking under the button- you may find slight adjustment to be made. You do this by removing the batteries and removing the fine screws that hold the top plate and /or back cover on. But don't hold your breath.
May 09, 2007 | Fuji FinePix S9500 Zoom Digital Camera
A flash problem
there could be a few reasons for that: 1. The Mode Dial has been moved to another setting - Set the Mode dial to the correct setting. 2. The flash is set to Suppressed Flash mode - Set the flash to Auto, Red-eye Reduction or Forced Flash mode. 3. You pressed the shutter button while the flash was charging - Wait until charging is complete before pressing the shutter button.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
Camera won't turn ON
First off, everything was not fine until this morning. You had this occur a month ago. Frankly, I would have done exactly as you did a month ago and nothing more. I have seen too many electrical problems permanently solved by turning a device off and then on, or by rebooting. Here is what I would generally recommend: 1. See what the camera manual suggests. 2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months. 3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves. 4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own. 5. Call Sony.
Sep 13, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Nikon Coolpix 775 Digital Camera Logo
43 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
