Question about Toshiba 42H81 42" Rear Projection Television
Sound but no picture, power light flashing
I can only turn off the power by unplugging it. I have sound but no picture at all, no LED messages, just a black screen.
    Problem Solver:
  • 7 Answers
The lamp could have broken try replacing it
Posted on Sep 18, 2008
LG LED TV 47ln5790 has no image but has sound. Brief flash of light when powered on and off. I can see image with flashlight.
I saw a youtube video where they replaced the led strips and it fixed the intermittent flashing screen issue
Oct 14, 2017 | LG Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
My 52 in jvc model lt-52x579 turns on but there is no picture or sound and about two seconds later the led light for the power starts to blink i tried to turn it off but it just keeps on trying to turn on...
Sound like the power supply board has gone out .Unplug the tv for 2 or 3 minutes and plug it in again and try to turn on. Some times they will come on .But It sounds like the PSB is going out .
Feb 14, 2011 | JVC LT-52X579 52 in. LCD TV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV picture wont come on, led light blinking, we have sound
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 30, 2008 | Toshiba 36HF73 36" TV
Toshiba 42H81 42" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
