Question about DTK PRM-0031I Motherboard
I have a DT16300-16. I dont use it for Top-up TV but the last few weeks it keeps recording programs from the Lottery Extra channel. I also keep receiving 3-4 minute recordings about top-up. I have had this recorder for nearly a year. Secondly, it seems to crash whenever it is recording and I delete a programme from it?
  • lyppy Sep 18, 2008
    Thank you for a quick response.
    I'm a bit crappy at tech stuff so maybe you could help me again??
    When I go into the main menu which sub menu do I go into? I've gone into the menus but cant find any auto update function.
    I went into the guide. The lottery channel is on top-up so have pressed top up on the remote, gone onto the lottery channel but I have no deselect button on the remote and there is no info shown on screen.
    On the customise top-up menu all the channels are de-activated but the lottery channel doesnt show on this list.
    Any help would be good and thanks again.
  • 293 Answers
The PVR you have has preset Top-up TV channels it will download from as a preset. You need to go into the main menu and turn off the auto update function of the machine. Then in your "TV Guide" menu find the particular channel and deselect it for download or recording.
The 3-4 minute recordings are commercials for their products and came with the last few auto updates, they're trying to sell their product.
A crash could be a sign of stress on the hard drive, most of these machines have craptastic hard drives that if even rattled or slightly moved while being recorded upon they die. If you're recording and deleting at the same time (with the age of the machine) I would not be surprised if it continued to happen. If it crashes when you do these things individually it is probably the same problem, or the firmware of the machine is corrupt.
Posted on Sep 17, 2008
  • Kristoffer Martin Sep 19, 2008
    Sorry I personally don't have this product so I'm making an educated guess from the PVR's I've worked with and the general manual for the product I found Online.
    If the lottery channel isn't showing up it could be part of a different menu. Is the Lotto channel an interactive channel? (as in the PVR has Interact technology allows you to use submenus on the channel?) if so it might not be removeable. Auto updates might not be able to be disabled on your particular unit model.
    Thinking as a different Idea to block the content is to put Parental locks on it. If you lock it completely out it shouldn't download any longer. If push comes to shove I'd call the manufacture's help line to see if it is part of the Top-up tv package and if you can get it removed from your package.
Why are the ends of somme recordings cut off?
this to allow some extra timing on the end to account for as to do with the timing of the program itself & not your TV. when recording a particular program it is a good idea to allot some time on the end to account for some stations overlapping.
May 15, 2015 | Panasonic Viera TX-32LX70 32 in. LCD TV
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Jvc av-20cm5 channel programming issue
you have a programing error in the main control ic it ca be repaired but its $$$$$$ my guess is 150.00 -200.00 the control ic has a modified control memory the memory is held in place by a charged capacator if you unplug it and leave it for a week and plug it back in it might be ok for a while if not try unplug it for a month . that might be enough for a reset but the problem will keep comeing back the chip is damaged
Apr 01, 2009 | JVC Televison & Video
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
my reciver dont recored and dont pause and take like 12 minutes to turning on, and have a message that a have to add a usb to help organize the programing a recored, o and is to slow that a have to keep presure the channel buton for like 5 seconts to make change
May 18, 2008 | DISH Network ViP622 DVR DTV Receiver /...
We have a sharp lcd tv c/w built freeview,the last couple of weeks it keeps losing just 1 channel ie bbc1 or itv1 every other channel is fine if we retune the tv everything goes back to normal, is it the...
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Apr 29, 2008 | Televison & Video
Computers & Internet Logo
115 people viewed this question
Top DTK Computers & Internet Experts
David Payne
David Payne
Are you a DTK Computer and Internet Expert? Answer questions, earn points and help others
