Laptop Sony Vaio
Lost my computer last year just found it I plugged it in light switch comes on but no screen screen is black is it ruined? My email is deblynn690@yahoo.com
  • The Cactus May 11, 2010
    Hello deblynn,
    It is possible, but there are a couple of things that you can try. I'll need a bit more information, though:
    1. What model of Sony Vaio is it?
    2. When you say light switch, I'm assuming that means you turned on the power. What else do you hear? Does a fan come on inside? Do you hear the disc drive move or any type of humming or clicking?
    3. Do you have access to another computer monitor?
    4. Where did you find it? Could it have been exposed to heat or pressure?
    It could be that a component inside needs replacing for it to work right. After a test or two, we may able to better tell. The above info would be a good start.
    ~Cactus
  • 5,568 Answers
You might remove the battery pack and try it on AC only; it's possible that the battery pack has died while it was not being used or recharged. If it does work without the pack, you can choose to make a permanent 'desktop' unit of it or bite the bullet and buy a new battery pack. If you buy a new one, shop the price; it can vary at least 2:1.
Posted on Sep 17, 2008
Sony Vaio E series laptop not turning on
check your ram slot.check your bios setup.or reset it.remove your battery press power button 3/5mnt and connect ac power now power on.
May 30, 2013 | Sony VAIO EB Series White Notebook...
Black Screen with 3 Beep Tones !
Probably memory stick(s). Are you comfortable taking a laptop apart to get at the memory sticks? If not, take it to a repair shop BUT at 9 months old, most units have a 1 year warranty. Contact the mfg with your purchase date, etc.
Oct 01, 2017 | Computers & Internet
Vaio PCG-9S1L Screen is very dark, extremely hard , LAPTOP SONY
As stated in your post "two year old may have dropped it"
If this is true than the backlight has probably been damaged. The small flourescent tubes that generate light through the LCD display.
Email service@lanprotec.com for service options
Mar 01, 2010 | Sony Computers & Internet
Light on the screen suddenly disappers
there is a invertor (fluresan invertor) in the LCD. invertor makes your lcd white, bright , lightly.  i think your invertor is breaking down. take the laptop to service.  sorry for my english.
May 27, 2009 | Sony VAIO Notebook
I have a problem with my Sony Vaio VGN- FZ112 laptop which I have bought over 2 years ago (therefore no warranty on it). I cannot start the laptop. When I press power on button the light switches on, every...
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 18, 2009 | Sony VAIO Notebook
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
POWER TURNS ON BUT SCREEN DOES NOT
Try Holding The Screen Up to A Bright Light And Look at it from an angle to see if you can see windows running without the light.... If you can..... The Problem Is Either Your LCD Bulb (needs Replacing) or It's the Power Inverter....
If.. You See No OS Running .. Just Black You Could Need Either A New Display ... or your Video Card/Chip is Shot...
Try Connecting an external Monitor if able to..... If It SHows Up On An External Monitor then Your Video Card/CHip is Good..
If You Get No Display, But The Black Screen Lights Up.... It Is Either The Display Cable Or The Display Panel Itself....
Nov 17, 2008 | Sony VAIO PCG-K23 Notebook
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
