Question about Canon imageRUNNER 5000 Copier
Ikon copier problem
I have a problem when I hit the clear function the copier keeps shutting off,
  • Canon Expert
  • 1,326 Answers
Dose it do it when you touch the Reset botton???? You may have a short or stuck botton on the control pannel...
Posted on Sep 21, 2008
Error code 000002 0006
It's a high voltage error. The machine probably needs the fuser rebuilt.
You can temporarily clear the code in service mode.
(if you dont do it fast enough the screen will shut off, just reboot and try again.)
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit
copier...
function
clear
err
then push ok on the screen, after that reboot the machine from the main power switch and it should clear.
May 15, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Hi, my problem is E000/0200 The machine shut down Thanks
You will have to clear the error .(Servce mode copier - Function-Clear- Err-OK) by keeping front doors open.After that Just check whether Lower roller heater lamp is working or not withe help of multimeter By taking out fixing assy.Prakashshalakas@mail.com
Sep 09, 2011 | Canon CLC 1150 Color Copier
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
My ikon Image Runner 2200 has an error message E000003000
All E000 codes have to do with the fixing unit. It can be reset but if the code comes back it will need to be serviced. It has been known to be caused by electrical noise on the main power supply so a filter might keep it from coming back.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again. You should now be in service mode. Select COPIER and this will give you some options along the top. Select FUNCTION. In the list select CLEAR. From the next list select ERROR and press ok. Then switch off machine and back on at the power socket. If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to mess a lot of things up while in the service mode.
Aug 05, 2010 | Canon Office Equipment & Supplies
How to reset Canon IR 8500 Machine Admin Password?
you need to go into service mode...... additional functions...then the 2&8 at the same time .... then addit funct button again
then you will hit copier tab
functions tab
the clear tab
pwd clr
then hit the ok button
that will hopefully clear the admin password
May 23, 2010 | Canon Office Equipment & Supplies
Canon IR1510 ERROR: E0000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Hit Additional Functions Key
    2. Hit # key
    3. Arrow to number 7, Printer and hit Set
    4. Arrow to number 4, Printer Re-Set and hit Set.
    5. Yes, re-set printer (hit minus key - back arrow).
    6. Unplug the machine and plug it back in.
Feb 22, 2010 | Office Equipment & Supplies
Need default passcode for canon iR 3025
Their is no default pass code, try to reset password thru service mode Additional functions, 28, additional functions, copier, function, clear ,clr pwd. That should clear all passwords.
Dec 23, 2009 | Canon imageRUNNER 4570 Copier
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
ADDITIONAL FUNCTIONS,
press 2 and 8 (together),
ADDITIONAL FUNCTIONS again,
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
Disable Canon IRC3220n build-in MEAP function
After you hit * 2,8* hit copier-function-clear-mmi then ok. This sets the machine to factory default.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Error code 000002-0010
You need to clear this fuser roller heat rod error in svc mode.
Additional Functions="star"
2and8= hit both keys same time.
Svc mode= star 2and8 star
copier/functions/clear/err/ok
reboot
If there is areal problem with fuser heat rods it will code again.
Nov 08, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
old marine
old marine
