Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960 Machine displays H2O probelm even though the water taps are on and the washing powder tray is clean and clear. Any cures?
  • 66 Answers
Its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Posted on Sep 21, 2008
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpoint washing machine WT960 is flashing F-12
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODESAccording to hotpoint website
Nov 26, 2011 | Hotpoint Washing Machines
Hi i got a hotpiont wt960 and i'm getting the h2o error. water is coming through the inlet pipe and the pressure is fine. i've replaced the water filter aswell as the pressure switch
Sorry- this is my 'standard' reply to water fill/H2O problems- hope it helps!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 07, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have for some months had to manually dispense the fabric conditioner to my service washing machine, I had this problem with my last machine but put up with it until the machine gave up the ghost. This...
Hi from retired Englishman in SW France @ 14:29 Tues afternoon- just after lunch and before going outside to do some (necessary) gardening!
Very common problem- often reported as 'water coming out of the tray and down the front of my machine' or 'there is still water and conditioner in the tray' !!!
What is often missed when cleaning the conditioner drawer is the tube/pipe bit which (normally) sticks up at the back. It has to be completely clear of any softener/powder mix. I clean ours quite regularly with something like a small screwdriver to literally scrape this gunge out- I blame my wife but don't tell her!
The pre-wash and wash trays have open ends because the powder sits in them until the water washes them into the machine. Because conditioner/softener is already fluid it would run straight into the machine as you poured it.
What should normally happen is that the fluid plus water siphons down into this tube and then into the drum.
I'm sure this should cure you problem- and probably your friend's!
Good luck,
John C
Feb 08, 2011 | Washing Machines
My machine no longer takes in fabric softener since I removed and cleaned the drawer. Behind the drawer was full of gunk and I cleaned that to the best of my ability and washed the drawer but now it...
(I have just copied this from my previous problem solution!) Hi from retired Englishman in SW France @ 14:29 Tues afternoon- just after lunch and before going outside to do some (necessary) gardening!
Cheers, John C
Feb 08, 2011 | Candy CN146 Front Load Washer
Hi there I have a Hotpoint WF541 washing machine. It has worked fine for 2 years, but now leaks a small amount of water from the soap dispenser down the front of the machine onto the floor. If...
Hi Sheena from retired Englishman in SW France @ 21:51 Sun evening (nothing on TV!)
Sorry if this seems a silly question/answer but have you removed the dispenser completely and ensured that it is not blocked anywhere, especially the conditioner/softener drawer area? Normally the pre-wash and wash powders sit in open ended trays to drop straight into the drum but the conditioner does not. It is not allowed out until the right time- it has to be flushed/siphoned out by the water feed. A common problem is that the tube/pipe which is in this tray down which it siphons is blocked- possible by a mix of powder and conditioner. It is easy to accidentally let the powder spill into it when filling.
My advice is to pull the drawer completely out and give it a good clean out, especially the conditioner bit!
Dispensers are removed either by pulling almost all of the way out then 1) pressing down on the lip at the rear to clear or 2) releasing the clip underneath the dispenser or 3) by lifting upwards just as you are pulling it out, whichever is the way for your machine.
Hope this cures the leaking!
Best of luck,
John C
Feb 06, 2011 | Washing Machines
Hotpoint WT960 has the H2o symbol flashing it has water and no pipe kinks
Make sure that the water pressure is o/k, and that the valve is fully turned on.
Also check the filter in the inlet valve, you wilave to remove hose to do this.
Mar 29, 2010 | Hotpoint Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
386 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
