Question about EliteGroup P4VMM2 Motherboard
P4VMM2 motherboard I'm trying to get this thing running for a family member. I need to find picture on motherboard pinouts (front panel USB, reset, etc) Any help would be appreciated ! Thanks, Jack Grochmal
You can download the manual from here (Europe) or here (US).
Posted on Sep 23, 2008
I have this MoBo, i only could tell you about the power, reset and leds pinout, its easy, starting from upper left pin to the lowest pin of the same row you conect in this order:
1 not used 10 not used
2 power white 9 Reset Sw
3 power red 8 Reset Sw
4 power led+ 7 HDD led+
5 power led - 6 HDD led -
i lost the usb conecction, im looking the manual, if i found it i'll tell you where to download it.
Hope you find this usefull
greetings from mexico
Posted on Sep 19, 2008
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
7th post down, - jondvd - 09-28-2008
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
May 14, 2013 | Computers & Internet
How to connect power to the front panel
Power to the Front Panel?
A) The plastic front of your computer is the Front Panel
B) The area of pins sticking up on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
I believe what you are requesting is the Front Panel header pinout.
AsRock Support > AsRock 775i65GV Motherboard > Main Support Page,
Go to the headings on the upper left side.
Products, Motherboard Series, 775i65GV, Overview and Specifications, and so on. Click on - Manual
On the next page go across from the heading - User Manual, and click on - Click Here, under the country nearest yours.
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to arrive at the page you want, or;
1) Put your mouse cursor in the page number box.
2) Left-click once. (Contents in page number box will be highlighted in blue)
3) Type the page number you want in the page number box.
4) Press the Enter key
Go to Page 10
This page shows an illustration of the motherboard, and as it sits in your computer case.
To the bottom Right corner is the Front Panel header. It is marked by the number - 16 [ System Panel Header ( PANEL_1) ]
{ It is the second header over from the Right side. It is Black in color. The first header is a USB header, and it is Blue }
Now go to Page 22. Front Panel Header Pinout. (System Panel Header pinout)
If you cannot download this motherboard manual, or if you do not understand the pinout;
There are 4 pins across the Top row.
There are 5 pins across the Bottom row.
The Top row of pins are numbered Even
The Bottom row of pins are numbered Odd.
Starting at the LEFT side going to the Right, on the Top row;
Pins 2, 4, 6, and 8.
Starting at the LEFT side going to the Right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
Pin 1 is for the Positive ( + ) wire.
IF the LED light is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset Switch, IF, a Reset switch is used.
Pin 5 is for Ground ( - )
C) Pin 9 is Not Connected. (N/C)
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the LED light is dim, switch the two wires around.
E) Pins 6 and 8 are for the Power On switch.
Page 21 details out the USB front panel headers, (USB 2.0 Header, Shared USB 2.0 Header), and the Front Panel Audio Header.
For additional questions please post in a Comment.
Dec 26, 2011 | Asrock 775i65GV Motherboard
Elitegroup mainboard p4vmm2 user manual Need to know panel 2 pin configuration for front panel connectors.
Are you use p4vmm2 (v1.1a) motherboard?
Download p4vmm2(v1.1a) manual guide to solve your problems,
==>> (CLICK HERE) <<==
hopefully this are can help
Jul 24, 2010 | EliteGroup P4VMM2 Motherboard
Asus P5LP-LE Motherboard Front Panel Pinouts
Mar 11, 2010 | ASUS P5LP-LE Motherboard
I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
Good luck,
Don't forget to rate my solution, thanks!!!
Jan 15, 2009 | Shuttle MV43VN Motherboard
PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in
if not it again so that we can suggest another site.
Jul 25, 2008 | Mercury P4VM800M7 Motherboard
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
493 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
