Question about Cameras
Sony DSC F-717...turn on camera, menu apppears...can do anything in menu, but cannot exit menu. pushing menu button to escape does nothing..reset button, remove battery, hookup to dc source, nothing works.
Sent it to sony
Posted on Sep 19, 2008
Wheres reset button on sony cybershot dsc w130???
I'm glad to provide the information about the Camera. The Camera does not have a RESET button to press manually to reset it.
If you wish to reset the Camera, you can use the Initialize option from the Menu item to perform it if the Camera is allowing it.
Please perform a power resetting if the Camera is not turning ON or you're unable to access the Menu items. Please follow the below steps to perform a power resetting
  • Remove the battery from Camera.
  • Press and hold the Power button for more than 15 seconds.
  • Reinsert the battery
  • Turn ON the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 12, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I have a sony cibershto 1080 model DSC-W200 and won't turn on I charged the battery but nothing. what can I do
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 27, 2009 | Sony Cyber-shot DSC-S980 Digital Camera
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Sep 19, 2009 | Sony Cybershot DSC-S950 Digital Camera
How to reset sony dsc-s40 camera
Hi
solution to reset---
press all 3 buttons on the back of the camera(MENU; Display/LCD on/off; Image size/Delete) simultaneously while turning on the camera.
Feb 26, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera problems
Go to camera Menu and select Initialize, this will Reset your camera to factory default settings.
Jan 08, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
DSC-W90 GOT WET AND NOW POWER BUTTON DOES NOT FUNCTION BUT CAMERA TURNS ON WHEN YOU PUSH THE MENUE BUTTON!!
it got wet and you are asking for help to fix it? maybe go to a nearby swimming pool, dunk it there for five hours and see if it works.
Oct 27, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
It will not turn on
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Dsc-N2 Buttons are mulfunctioning.
Its possible the button board under the rear case has been shifted or is malfunctioning. You can try to remove the back case and see if you can realign, or reset your camera's button board. If this doesn't work, there are several online companies that can help -
DarnToothySam.com has several repair estimate opportunities, and is pretty reasonable for the price.
Dec 20, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
