Question about Dryers
Hotpoint ultima TL41 sensor dryer worked intermittently, now stopped
SOURCE: Ultima Condensor Dryer
Fixed it. I managed to find out the problem was, it was the two heat sensor at the back of the dryer. Once changed it was ok.
Lets see how long they last.
Posted on Nov 26, 2007
  • 1294 Answers
SOURCE: Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 24, 2008
barkencoa
  • 3463 Answers
SOURCE: i have a hotpoint ultima
Check your user manual for faults to be found at the rear of the manual.
If you don't have a manual go to www.hotpoint .co.uk.
Click on After sales, then on download user manual.follow instructions.
Good luck.
Please leave feedback.
Posted on Nov 30, 2008
  • 135 Answers
SOURCE: E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Condenser Dryer - where is the reservoir?
under the door, you need to take the small panel off and its there.
Mar 03, 2009 | Hotpoint Dryers
Washer dryer wont stop running
unplug the machine for 3 mins and plaug back in if it still happens you might have a problem with the heating element or somthing.hope this helps.
Jan 02, 2009 | Hotpoint Aquarius WD63 Front Load...
E30 error code
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965
Hotpoint Ultima WD72 Front Load Washer/Dryer
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
93 people viewed this question
Top Dryers Experts
