Question about Daewoo DVN-14F6N 13" TV
DVN-14F6N Daewoo
I have a Daewoo DVN-14F6N, that my mom gave to my kids to watch cartoons on, but there is no remote and no controller. The vcr is all static but I can hear it the movie, and the channels are set on cable between 53-98 or something like. How can I change the channels and also change it over to antenna if I decide to move the tv away from the cable. I do not have the remote. I cannot find any information online, and Daewoo said the tv is too old they dont have anything.
thanks for any help possible.
Kelly
4 Suggested Answers
  • 84 Answers
SOURCE: Daewoo DVN-14F6N
if your tv has a cable box, your connections should be as follows:
cable line from wall to cable box input. output from cable box to vcr
input. vcr output to tv input. both the tv & the vcr should be on channel 3
if you are using the rca cables,(red,white &yellow) just match the colors of the outputs
from the cable box out, to the vcr in, then vcr output to the tv. you will need to
put the vcr or tv on a aux channel or line/source input.if you don't have a cable box,
your vcr can be your tuner.scroll down on the tv channel down button till you
get to channel 3 or line in/source.if your vcr has all the channels programmed,
you can use the vcr remote to change channels.since you don't have tv remote.
most tv's if you scroll
down under channel 2 will give you the aux/line in/source inputs.
in some dollar stores they have universal remotes that may control
your tv.you can also try radio shack. let me know if this works.
the ledge
Posted on Sep 18, 2008
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Posted on Apr 23, 2009
darjr
  • 378 Answers
SOURCE: My son's Daewoo#DVN-14F6N has Audio/Video, but are
that are input only. yes you can connect your dvd player, use a AV cable ( Yellow and White)
Posted on Sep 13, 2009
How do I change from anntena to cable the menu dose not have a choice to do that
Hello, the original remote has a "tv/catv" button on it and that's how you select whether your on cable or antenna. tks
Nov 08, 2013 | Daewoo DVN-14F6N 13" TV
The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
I connected audio and video wires in front and I would like to swith to external input but there is no switch. I tried all different channels but does not work. How do I watch external device?
You must select "AV in" mode on the Remote to get the signals on this connection.. If your TV has more than one input (one at the back too) than you have a selection of "AV1" and" AV2 " to switch on these two..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Daewoo DVN-14F6N 13" TV
My son's Daewoo#DVN-14F6N has Audio/Video, but are these Output, or Input...as I wish to connect a DVD player. Thx
Sep 13, 2009 | Daewoo DVN-14F6N 13" TV
My tv is stuck in teh stand by mode...how can i fix this
Have you tried unpluging it for a few minutes, then plugging it backin?
Sep 08, 2009 | Daewoo DVN-14F6N 13" TV
Daewoo DVN-14F6N
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Cable to Antenna Issues
You would need to purchase a universal remote, and once you program the universal you would be able to change from cable to antenna or vice versa.
Although there is a slim chance that in the setup screens on your TV (if you can access them by pushing a button on the tv) would have a selection where you could change the 'input' that is selected. If that is not an option, then it is definitely time for a universal remote.
Jun 23, 2008 | Daewoo DVN-14F6N 13" TV
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
No Power... Main Fuse Blows right away. Resistor R809 has its outer layer burned off so I cant tell what value it is.
I would check the rectifiers (diodes) all 4; one or two may be shorted. Check color code for R809 or may have number on it if it is white square resistor
Dec 29, 2007 | Daewoo DVN-14F6N 13" TV
Daewoo DVN-14F6N 13" TV Logo
60 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
