Hello, My Westinghouse ltv32w1 LCD TV is only 2 years old. Sound is fine, picture is not so good: Initially when TV goes on picture is okay, then after 30 minutes, the image breaks up into verticlal lines and is unviewable. Other times, the color gets distored. There are "hot spots". Bright colors, for example flames in a fire place, become pixelated and lose resolution. Then people turn green and purple. Thank you, Kathleen Fisher
  • fisher_kat Sep 17, 2008
    My posting is listed under projection TV and of course it is LCD.
    I have 4 emails saying 4 experts have made comments, but only one solution is showing.
    How does this work?
    KF
    My last solution is listed under the category of projection tv, my tv is LCD. I have no further details to add to my problem, but would like to know the approximate cost for the replacement part and whether it can be done by me.
  • 10,594 Answers
Symptoms of tv shows problem in LCD Controller board and hopefully fault can be fixed by replacing LCD Controller board.
Board can be purchased from Part Store on $74.22 only.
It would be better to get service of qualified tech person for board replacement.
Regards,
Posted on Sep 17, 2008
  • Shahid Electronics
    Shahid Electronics Sep 18, 2008
    did you see solution what I posted here?
  • 2,323 Answers
The behavior from your LCD means that there could be a power supply failure starting to developed due to leaky or dry capacitors.
The power supply might not be available anymore since is not being manufactured for this LCD model.
Click here to see if these guys can find you a power supply.
Let me know if you need further assistance.
  • Jaime Hernandez Sep 17, 2008
    Power supplies fail in about 95% of the time.
    The cost for the repair will vary. I would suggest to contact your local service repair center and ask them how much it will cost you to have it fix.
    There are repair service techs that could fix the power supply for around $100.00
    Sergeant:
  • 399 Answers
Its the problem of convergence STK ic.you will have to replace the stk ic on the main board to make it work normally.
thanks.
  • masterexpert Sep 17, 2008
    if you have any technical knowledge of soldering you can do it your self and will cost u approx 120$ .
    Guru:
  • 1,894 Answers
Verticle lines are most likely a bad tube or convergence problem. You will not be able to fix this your self . I suspect a bad convergence ic
  • 1 more comment
  • dewan nafees ahmed Sep 17, 2008
    I suspect a bad convergence ic cost for parts are around 30$ service
    charge around 150$ to fix. At least know when you call a service person you
    will have
    a good understanding of problem.good luck.
    Try a hard reset a couple of times and see if that helps. If not, you will need an expert tech to look at it.
    Reset is best done by disconnecting the power cord from the wall outlet
    for 4 hours; then power up. Do it twice. Then let me know - - or
    all in a repair expert.
    It is not an adjustment; it is a malfunction
    it can also be a malfunction of either the vertical deflection system or the auto format switching circuits.
Tv turns on but no picture
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
The TV is about 6 years old and it will work fine for about 10 minutes then it must heat up or something and the picture goes blank
The tv LCD screen panel go black blank,but dose the tv still have audio sound of the program?Yes?The tv have 1 or 2 a long boards that are called a LCD inverter boards.It is dying and require replacement.These 1 or 2 a long LCD inverter boards only job are to provided a backlight for the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes long LCD inverter boards for the replacement.
Sep 03, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse sk-32h590d wont turn on ????????
is ur tv under 5 years old and u live in the uk phone the manufactorer and tell them about it if they give u rubbish about warrinty tell them about the sale of goods act for a tv it states a tv shold be reasonabley durable and of good quality for around 5 years if no anwser phone trading standards
Jun 02, 2009 | Westinghouse SK-32H590D Television
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
LTV-30w2 Backlight problem...goes black
turn light in room off, take a strong flashlight and shine at an angle and see if you can see picture.If you see picture then it is inverter problem.part number 4900506280,I think.
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Westinghouse lcd tv parts
can I have your LCD SCREEN? Mine is cracked and I sure could use a new one, or used if thats the case =)
Aug 20, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-13W3 blue Screen
I have the same problem. It happened to me 2 days after the warranty expired. I took it to the repair shop and they told me the tuner went in it.(BTW $400 to repair, I did not do it) I have yet to get a TV picture through it, but can run a DVD through it using the Pr etc. component inputs... Any information you have gotten might be helpful to me too. Good Luck.. Westinghouse is off my list of products to buy I know that.
Aug 25, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
