Question about Vacuums
Wont pick up water - Vacuums
  • 120 Answers
Unless its a wet dry vac you should not use a normal vacuum to **** up water, you could kill a normal machine that way
Posted on Sep 18, 2008
Changed hose on carpet cleaner and it wont pick up the water
If you are unable to pick up water from the carpet after using the hose attachment, is is usually due to one of two reasons.
1 - The duct on the front of the dirty water tank has not been put back in place after using the hose. It is a square plastic piece about the size of a slice of sandwich bread.
2 - The lid is not properly seated on the tank. Be sure to hook the two tabs on the front edge in place before hooking the latch at the rear. This also applies when using the hose.
Feb 19, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My steamvac wont pick up the water. it is spinning and blowing out the water, but it wont **** it back in
The most common reason for lack of pick-up is that the lid is not seated firmly on the recovery tank. Lack of pick up is always caused by an air leak. A less common possibility is that the large round rubber seal that the recovery tank sits on has fallen out of place. If you look at the bottom of the tank, you will see a round hole. When you install the tank, this hole sits on top of a rubber seal on the motor shell. Be sure the seal is in place.
Feb 05, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
Wont pick up water
if it does not pick up water and the vacuum motor is running you have either a blocked hose or a bad gasket allowing vacuum pressure to escape.
Jun 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Apr 30, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My machine wont pick up the dirty water. If I take the cover off the recovery tank there is a lot of suction but it wont **** up the water. my carpet is soaked. What can I do
at power head clean out area before power head also look for small hose and clean out and look at rollers,i hope this works if you have directions still they should be able to help you out some more.thanks
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water will not spray out and pick up
My steam vac wont spray out the cleaning products.
Feb 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Need help
There is a rubber gasket that sits between the tank lip and the clear nozzle window. Part #2104052, also the the filter on the under side of the lid is clogged. 2104052
Oct 07, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
85 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
